A Study of DML's as a Full Range Speaker
Thread Tools
Old 2nd August 2021, 05:15 PM   #3421
spedge is offline spedge  United Kingdom
Default Hans Theesink.
a very quick recording of the eps panel on the left and the canvas panel on the right.
i just guessed at the 200hz xo for the panels and sub and also the levels so i hope there is not to much bass?
i also should in future restrict the recordings to 4mins so i can use the 256kb as the sound is so much better, but as i said this was a very quick recording.
you tend to loose a lot of detail and ambience .
hope it still sounds ok.
steve.
Old 2nd August 2021, 05:41 PM   #3422
andreas.
it probably depends on how you would define a quality amplifier ?
now days if an amplifier sounds very good to me , then thats good enough for me.
over the years i have heard some pretty bad sounding amps, and most were given rave reviews by the hifi press.
i even paid money for them
i was an early convert to the lowly digital amps and could not understand why they got such bad press, maybe i was just lucky in my choices ?
i have built a few amps in the past such as the JLH 10watt CLass A,which i realy liked, but the heat
the price of cheap good sounding digital amps including the higher end HYPEX(quality )amps, made it a pointless task building them as i could not buy a transformer for that price
so what is a quality amplifier now days ?
steve.
Old 3rd August 2021, 11:51 PM   #3423
Default running water
i was looking through my cds to play on these panels and i was reminded that even in my early days of dml using corrugated cardboard,that the sound of running water used to sound so realistic .
natural sounds come across so naturally , you could almost reach out and touch the water.
hopefully this recording will show this .
most speakers will make a sound that will sound like frying bacon.
steve.
Old 4th August 2021, 10:40 PM   #3424
Default Naked canvas panel
I was looking at the canvas art panel last night and realised that with all the cracks in it that it was not rigid at all in fact it was very floppy.
So I decided in a very quick decision to glue an exciter on to a brand new canvas panel with a brace at the back to support the exciter.
And that was it,nothing else just the canvas and the exciter.
It only took about half an hour to find and saw the wood for the brace and to put everything together and glue.
I have not had time to assess the sound yet but took some quick pictures of the panel and a response at 12inches.
This panel rolls off at about 300hz which is handy as this is the normal roll of on my TLS,so i xo the panels to this so no overlap anymore.
Hopefully I'll get a chance to listen tonight
Steve.
Old 4th August 2021, 11:04 PM   #3425
mexjerry is offline mexjerry
do not JAM the exciter into the material
Old 4th August 2021, 11:10 PM   #3426
57buick is offline 57buick  United States
57buick's Avatar
I agree with @mexjerry be careful about the depth of the brace not pushing the exciter against the canvas or that will kill your low end and probably your detail
Im not using a brace, I just used PVA primer to cover canvas then used the pva to stick a thin piece of balsa onto the panel then stuck my exciters to that and I get awesome response curve!! it doesnt even roll off till 150 or 200 sounds amazing!
Old 5th August 2021, 12:00 AM   #3427
mexjerry and 57buick.
as you can see from my photos the canvas is perfectly flat and there is no ply panel involved , just the coil glued to the canvas.
if my 6x4inch ply was attached there would be no roll off at all until 40hz and that is with a single 10watt exciter.
this was just an experiment to see what a naked coil on the canvas would do and to prove that the ply was the main drive below 300hz.
this could also be other materials or something like a fiberglass coating or both.
ive done a few quick recordings for you of the naked canvas and exciter.
i still have not had time for a good listen yet.
steve.
Old 6th August 2021, 02:09 PM   #3428
The glue has pretty much dried now so took some more pictures of the full range response at 12inches and at 3m.
The response for the 12inch plot is a lot better below the 300hz mark holding up well down to about 125hz(about -10db or so) but is still outputting down to 20hz.
On the 3m full range plot ignore everything below 100hz as this disappears into the outside noise .
I decided to let the panels run down to 100hz before xo and run the sub up to 300hz this gives a nice sounding response.
What next, should I soke the panel in 50x50 mix pva and see what happens?
Any suggestions?
The response of my badly cracked cascamite canvas panel above 300hz is identical to this panel so did not take plots .
Although the low end is a lot stronger, even though the panel is quite floppy because of the cracks, maybe too much air is seeping through the naked uncoated canvas?
I'm in no rush.
I've been having a little listen while writing this ,and they seem to have quite a smooth sound, with plenty of space and detail .
Not bad for the amount of money and effort I put into building it.
I'm wondering how much more I can squeeze out of them with a little effort?
I have noticed that the exciter starts ringing on loud piano ,I know I have at least one duff exciter and it looks like I put it on this panel
Must remember to mark it this time
What a pain.
Steve.
Old 6th August 2021, 09:38 PM   #3429
Default Handel Theodora naked canvas
i was looking for this cd for many months but could not find it ,then suddenly there it was ,unbelievable !
anyway i had to record this track ,it does not make my skin crawl with the pain in her voice like on my best panels but its all there.
steve.
File Type: mp4 with darkness deep as is my woe mp4.mp4 (6.95 MB, 28 views)
Old 7th August 2021, 12:22 AM   #3430
Jim G is offline Jim G  Canada
Default Handel Thedora naked canvas
Hi Sedge, Your best panels are ???
A Study of DML's as a Full Range SpeakerHide this!Advertise here!
Thread Tools
Full Range Voice Range single speaker and enclosure loninappleton Full Range 23 8th May 2014 11:14 PM
Proposal for a full range speaker radio Full Range 20 23rd April 2014 05:03 PM
Design Study: Full Range Line Array Dumbledog Multi-Way 5 27th October 2013 12:45 PM
Full range speaker package. perceptionchanges Swap Meet 1 15th July 2013 03:08 AM
Full range active speaker zebra100 Full Range 10 24th August 2009 11:28 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
