WAW / FAST build ?
WAW / FAST build ?
Old 27th February 2015, 12:26 AM   #1
ton def is offline ton def  United States
Default WAW / FAST build ?
I have a pair of Alpair 7 and sdx7 that I bought several years back. I would really like to start a build with these. I would likely need to use a passive x-over,as I have no dsp or experience with them. Any plans or examples of this ? I have seen planet 10's ,but I do not quite understand PLLXO. Thank you
Old 27th February 2015, 01:00 AM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
WAW / FAST build ?
PLLXO is less expensive. Hopefully Dave can chime in soon.
Old 27th February 2015, 01:38 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
WAW / FAST build ?
And really easy to build. Do you have 1pr SDX7 or 2?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th February 2015, 03:36 AM   #4
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Consider DSP and bi-amping. The price of admittance has gone down seriously in the last couple of years.
Bob
Old 27th February 2015, 04:05 AM   #5
dave
I have one pair of sdx7. Is your design adaptable to use only one sdx7 per speaker ?
Old 27th February 2015, 04:09 AM   #6
Bob
Yes, that would probably be the best way to go.... But I am not knowledgeable with that technology ( and cash limited ) .
Old 27th February 2015, 04:35 AM   #7
frugal-phile(tm)
planet10's Avatar
WAW / FAST build ?
Sure. It makes a passive XO possible, but the A7 may need padding down.
dave
Old 27th February 2015, 04:57 AM   #8
dave
By padding down the a7, do you mean attenuation for spl equalization or limiting current to it ?
Old 27th February 2015, 05:39 AM   #9
frugal-phile(tm)
planet10's Avatar
WAW / FAST build ?
Reducing its SPL.
A point to keep in mind is that by the time you sort passive parts their cost will very likel be in excess of what a 2nd amp (something like a TDA2116 or 18 would be fine) & PLLXO will cost.
dave
Old 27th February 2015, 10:23 PM   #10
chrisb is offline chrisb
I don't think the question as to how PLLXO is implemented has actually been described, this primer is as good a place to start as any, and includes an excel calculator to determine component values.
TLS.org | Passive Line-Level Crossover
In short, it can be as simple as a pair of resistors and very low value caps at the input of each amp - they can even be soldered directly at the input jacks with a bypass switch for full range.
Dave: note that the link to Alex's website on the bottom of BSC page is now 403
Technology honors no Hippocratic oath
WAW / FAST build ?Hide this!Advertise here!
FAST build - need suggestions ani101 Full Range 11 17th May 2014 05:25 PM
The ultimate FAST build? lorienblack Full Range 11 23rd March 2014 08:47 PM
My odd little WAW/FAST with CHR-70.3 build satx Full Range 10 17th April 2013 06:08 AM
A fast way to build FAST solhaga Full Range 36 15th December 2012 11:32 AM
I need a really simle and fast amp to build trespasser_guy Solid State 12 15th August 2002 09:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
