some samples box very good  for full-range speaker
Old 1st September 2015, 10:34 AM   #161
vvxuan is offline vvxuan  Viet Nam
Originally Posted by sachu888 View Post
Hi Vvxun
I am very much interested.
Sachin
Thank Sachin, You can use this design for driver 10 to 12 inch.
And completed plans
and some pictures for during building
Old 1st September 2015, 10:47 AM   #162
This design good for driver 10 and 12 inch, because with driver 8inch they have bass ranger under 35hz (My microphone can't measure ranger under 35hz). Bass ranger of driver 10inch and 12inch better than the driver 8inch verry much. Next time i will to buy a microphone can measure bass ranger better...
Old 1st September 2015, 12:23 PM   #163
sachu888 is offline sachu888  India
sachu888's Avatar
Thanks Vvxuan for suggesting a good TL design.
This design looks very good and simple enough to build. Few people have suggested to build big old style bass reflex enclosures but I have got very good result by TABAQ using small 3.5" drivers. I feel this TL design will give me very good Bass.
Please note my driver of coaxial driver with horn integrated in it. Please see pics below
Sachin
Old 1st September 2015, 06:29 PM   #164
Sachin
Hi Sachin! You can use this driver in my design. You will remove the small hole (for tweets) and move the big hole (for driver bass) up to, about 10cm, you will have a nice design for your drivers. If you like bigger design for driver 12inch, you can extend width of enclosure from 35cm to 40cm.
You should add the splint to make more solid enclosures.
good luck!
Old 1st September 2015, 06:41 PM   #165
sachu888's Avatar
Thanks vvxuan,
your posts are really helpful. I will build this enclosure for my drivers.
Sachin
Old 1st September 2015, 07:01 PM   #166
bolly is offline bolly  Canada
bolly's Avatar
vvxuan, is post 27 for coral beta 8?
Old 9th September 2015, 06:55 AM   #167
atilsley is offline atilsley  Australia
VVxuan
Here's an interesting one for you.
Altec 420A 16 inch driver.
What box/port would give a good response?
http://www.greatplainsaudio.com/vint...spec_sheet.pdf
Xmas inches 0.15
Re 4.6
Vd 19.2
Fs 22.6
Vas 28.2 cu ft
Ref 1.7
Qts 0.47
Qms 6.59
Qes 0.51
Vid 0.20
From memory, not unlike the famous Altec 416.
I am just about to start a build using a ported box for this driver, 8.5 cu ft (250 liters).
Regards.
Andrew
Old 8th December 2015, 03:45 AM   #168
diysfx is offline diysfx  Sikkim
hi, VVxuan, thanks for yr contributions.
been reading this forum for diy ideas, found yr's most helpful.
yr design allow for unknown/old drivers without spec to good use.
had read Xrk97 thread, its quite technical and need for drivers data sheet,
but optimize for best result, more to serious built with very good results.
i'm looking for a built to use some unknown drivers for desktop use.
looking forward to yr ideas for smaller drivers 5" to 3", thanks.
i guess small drivers dont get the good bass. Might use yr box size,
and take Xrk97 formcore ideas for cheap builts, thanks!
Old 21st January 2016, 06:46 PM   #169
hego is offline hego  Europe
Anything else?
Very simple solutión and interesant.
I like it.
Cheers
Old 7th March 2016, 12:58 PM   #170
dundo is offline dundo
Hi Vvxuan,
I am really impressed with your results with such a simple design, compared to complex horns... Since I own a spare pair of Fostex FE206E (treated at Decware), and I am in search of boxes for them with strong WAF I found you pages.
I see that started moving the "mouth" of TL designes to a side of boxes. Have you made any for 8" and if so would you be so kind and send me such a plan? These have an extra WAF (wife acceptance factor - happy wife - happy life).
My material of coice would be MDF.
I thank in advance and wish you many new successes in future.
Cheers
some samples box very good  for full-range speakerHide this!Advertise here!
New full range system in a box colossusfan Everything Else 3 31st July 2015 09:23 PM
Full Range Voice Range single speaker and enclosure loninappleton Full Range 23 9th May 2014 12:14 AM
Good full range speaker Gost22 Full Range 10 8th March 2013 02:38 PM
Full range in a closed box? Racket Scientist Full Range 4 21st August 2010 06:58 AM
Copyright ©1999-2019 diyAudio
