A mini fullrange driver comparison - what should i build?
Thread Tools
Old 2nd October 2014, 07:59 PM   #1
theKenDo is offline theKenDo  Germany
Default A mini fullrange driver comparison - what should i build?
I am currently into small fullrange drivers. I want to build two small Transmission Lines for my pc.
So i compared three speakers:
1. Dayton Audio CE Series CE46P-4 1-7/8" Paper Full Range Driver
2. GRS 3FR-4 Full Range 3" Speaker Driver 4 Ohm
3. Peerless TC6WD02-04 Silver Series 2" Midrange
I simulated these drivers with Leonards Audio Transmission Line Software in different TMLs.
1. I simulated a TML with 12 cm² start and end-area and 100cm length. The predicted frequency response goes down to 80Hz. The driver is at 1/3 of the line (33cm from start).
2. I simulated a TML with 50cm² starting area decreasing to 35cm² end area. The line is 80cm long. The predicted frequency response goes down to ~85Hz. The driver is at ~1/3 of the line (28cm from start).
3. I simulated a TML with 20 cm² start and end-area with 100cm length. The predicted frequency response goes down to ~80Hz. The driver is at 1/3 of the line (33cm from start).
Does anyone here has experiences with these drivers? Which speaker would you choose?
Old 2nd October 2014, 09:04 PM   #2
R.I.P.
None of them :
The peerless needs a tweeter
The GRS has no specified response
The dayton is too small, low power, low sensitivity.
I'd use this : (seen its specs and response somewhere)
Tectonic Elements TEBM65C20F-8 3-1/2" BMR Full-Range Speaker 8 Ohm
with :
Lepai LP-2020A+ Tripath Class-T Hi-Fi Audio Mini Amplifier with Power Supply
rgds, sreten.
Old 2nd October 2014, 11:46 PM   #3
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
just throwing another driver in the mix
https://www.parts-express.com/pedocs...ifications.PDF
Old 3rd October 2014, 02:13 AM   #4
Bare is offline Bare  Canada
Don't be throwing a Cheap low grade Chinese Amp into the fray.
The Lepai is complete and utter Junk .. in my (repeated ) experiences, describing it charitably/politely .
I was convinced that my admittedly entry level Mark Audio drivers were worthless/bad performers, based on what they sounded like on several Leapis (All of which died in short order, just to add insult to injury)
Fitting a Real amp to the Mark Audio drivers was an epiphany.
Garbage in most certainly equals Garbage out.
Old 3rd October 2014, 02:33 AM   #5
rjbond3rd is offline rjbond3rd
Originally Posted by Bare View Post
Fitting a Real amp...
What amp?
Old 3rd October 2014, 04:56 AM   #6
Mayuri is offline Mayuri  Finland
Mayuri's Avatar
Here's what I'd recommend (from Eu, as shipping from PE or Madisound will bleed you dry):
Peerless (Vifa) Breitbandlautsprecher TC9FD-18-08 (9 BN 119/8)
Faital PRO Breitbandlautsprecher 3FE25A
Both are cheap, tested and proven good.
Old 3rd October 2014, 05:33 AM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
My favorite small FRs are Fostec FF95wk & Mark Audio Alpair 6.2p
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 3rd October 2014, 05:37 AM   #8
TMM is offline TMM  Australia
Send a message via AIM to TMM
This may be of interest to you:
http://tinyurl.com/lmqoe4r
Old 3rd October 2014, 05:59 AM   #9
big russ is offline big russ  United Kingdom
This is very interesting to me as I'm about to do something similar.
I already have the vifa driver recommended by Mayuri in a small sealed box crossed over to a sub and I think it sounds great.
This system is moving so I'm going to build something new and was considering a small tl like you. I've recently acquired the hiwave driver recommended by sreten for this purpose and was looking at modelling it in something like the tabaq or lance speaker (both found on these forums).
Anyway the guy at spectrum audio (mayuri's link) seems to recommend both these drivers and stocks many more so it may be worth speaking to him. This assumes of course that you're happy to invest in more drivers ��
Old 3rd October 2014, 07:45 AM   #10
@sreten
Frequency Response: 150 to 20,000 Hz
Frequency Response: 135 to 16,000 Hz
Fs: 135Hz
Because i only use this speakers as pc speakers or in quiet environments it's okay if it has low power. What do you mean with "low sensitivity"?.
A mini fullrange driver comparison - what should i build?Hide this!Advertise here!
Thread Tools
Mini/Prime Fonken - Paradigm comparison? Perhaps Planet 10 hifi 3 24th March 2011 09:04 AM
An easy and fairly inexpensive DIY Mini Monitor with a Fullrange Driver ThorstenL Full Range 33 6th July 2006 02:34 PM
4 inch fullrange comparison wron Full Range 7 28th June 2006 09:46 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
