planet10 said:
1/2" ply would be better.
dave
RAW said:I agree with Dave.
1/2" ply would be better than 1/2 MDF.
Al
Can you guys tell me why? I am somewhat confused...
coolkhoa said:Can you guys tell me why? I am somewhat confused...
Short answer: Plywood -- you need to use quality, void-free ply -- is stiffer, so you end up with a better sounding box. MDF is used alot because it is cheaper (~50%), easier to work, and easier to finish.
dave
coolkhoa said:0.8 cu ft box filled with enough damping material to "virtually" increase volume to the minimum recommended 0.1 cu ft?
Do you mean 0.08 ft^3? I'd stick with the minimum recomendation....
dave
dave
Yes, I meant 0.08 cu ft. Thanks.
dave
What about the claim of MDF being acoustically "dead" and anti-resonant? It is also less likely to warp and bend than normal wood, right?
coolkhoa said:MDF being acoustically "dead" and anti-resonant?
Which tends to have it store energy and release it later.
dave
plywood/mdf/etc...
One important point to keep in mind is that the stiffness goes up with the square of the thickness, so, 3/4" is more than twice as good as 1/2" (and 1" is 4x as good as 1/2", and so on...). Also, using layers of dis-similar materials tends to reduce resonance.
The closer a side of a speaker is to facing you, the more important it is to damp/stiffen it (somewhat) so I tend to add an extra layer to the front.
The stiffer your box is, the more bass you'll get. But, even a super stiff box made out of say, steel, will ring like a bell if it isn't well damped (so it will sound like crap).
Try playing sin sweeps and see if you can feel any parts of your cabinet that are resonating particularly and those are problem areas you should address - either by making the wall thicker, adding a brace, or some kind of damping.
One of the best things you can do is add internal braces to your cabinet design. The advantages from stiffening your cabinet almost alwasy outway the lost cabinet volume.
Re: plywood/mdf/etc...
On the other hand, as the material gets thicker it resonates at a lower frequency meaning that it is more likely that there will be enuff energy to excite that resonance.
dave
critofur said:One important point to keep in mind is that the stiffness goes up with the square of the thickness, so, 3/4" is more than twice as good as 1/2" (and 1" is 4x as good as 1/2", and so on...). Also, using layers of dis-similar materials tends to reduce resonance.
dave
Re: Re: plywood/mdf/etc...
wait a minute... are you saying that 1" MDF would resonate at a lower frequency than .5" MDF? I thought stiffer = higher resonance frequency...
Dan
dave
Dan
Re: Re: Re: plywood/mdf/etc...
There is a thickness term in there too... the thin string on the guitar resonates at a higher frequency.
There is also a tendency to brace the 1/2" box more, and mine would be made of plywood.
dave
owdi said:wait a minute... are you saying that 1" MDF would resonate at a lower frequency than .5" MDF? I thought stiffer = higher resonance frequency...
dave
Considering all this talk about cabinet resonance, what thickness do you guys think is best for the 871: 1/2", 3/4", or 5/8"?
Another question: if you discover that the cabinet strongly resonates at a particular frequency, is there any way you can tame it at that frequency?
Thanks for all the replies and for not minding me asking too much.
If you all must say plywood, what kind should I buy? Birch? Maple?
If I choose to use veneered ply, external fasteners (i.e. screws) should not be used at all; I don't want to ruin the finish. A good option then is to use dovetail joints (which are held together by glue alone) instead of the common butt and miter joints. Is this feasible for larger cabinets?
Joinery good, screw bad.
coolkhoa said:If I choose to use veneered ply, external fasteners (i.e. screws) should not be used at all; I don't want to ruin the finish. A good option then is to use dovetail joints (which are held together by glue alone) instead of the common butt and miter joints. Is this feasible for larger cabinets?
You can still use external fasteners if you use a plug cutter to cut matching plugs from matching plywood to cover the screws, and drill recesses for the screws beforehand.
As for dovetails (wow!) or even finger joints, I think you can only reasonably expect to use such techniques for 4 sides, and then some other technique for front and rear. I can't imagine the effort and patience it would take to do all 6 sides in dovetails!
Stiffness goes up with the square of the thickness, so the frequency will be increased.
While it's true that because the Young's Modulus of MDF is about 1/3 of typical plywood, it will resonate a lower frequency, it's Q is also much lower (in plain English: more "acousticly dead") so it is harder to excite the resonance and the resonance dies off quickly. The sound engergy transfered into the MDF is more quickly dissipated than with a plywood enclosure (it's converted to heat).
Hardwoods have a much higher Q, so while they are stronger/stiffer, they also resonate more so they are more suited to acoustic instruments where you WANT resonance, than to speaker cabinets.
Your best bet for reducing cabinet resonances is to layer materials with substantially different Young's Modulus, perhaps making a sandwich with a visco-elastic damping material in the middle. Bitumen is my favorite, but there are a variety of damping materials you can buy, usually with double-sided adhesive, or, the material itself is adhesive. Presently, I no longer have a source for rolls of bitumen sheet.
planet10 said:On the other hand, as the material gets thicker it resonates at a lower frequency meaning that it is more likely that there will be enuff energy to excite that resonance.
- Full Range
- Cabinet for Tang Band W3-871S
