PRV 5MR450-NDY for FAST/WAW applications
Old 18th October 2019, 06:45 AM   #561
spatch is offline spatch  United Kingdom
I now use the PRV 5MR450 with the Beyma in a Baffleless line array design
I found the Beyma a bit light in the mid-bass region but better in the treble. Now have the best of both designs
Old 18th October 2019, 07:10 AM   #562
k9vap is offline k9vap  United Kingdom
Old 18th October 2019, 10:57 AM   #563
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Nice! Must sound amazing. Watch out for those high SPLís with this setup. Easily 105dB/watt
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 22nd October 2019, 09:41 PM   #564
Defo is offline Defo  Norway
Would this driver work in a backloaded horn kit from Madisound I wonder?
Fostex BK-12m Folded Horn Cabinet - Each
Old 23rd October 2019, 07:33 AM   #565
Got Foam?
xrk971's Avatar
No, TS parameters are too different. Mostly Fs, Qts, Vas are too far off,
Old 23rd October 2019, 10:31 PM   #566
jdubs is offline jdubs  United States
Hey guys, how are these drivers with "complex" music? I've heard full-range drivers that just fall apart with anything other than simple acoustical material.
Thanks,
Jim
Old 24th October 2019, 12:35 AM   #567
Got Foam?
xrk971's Avatar
They play complex genres very well when used in a FAST - with a woofer for stuff below 300Hz. Great with speed metal or orchestral symphonies. Their high sensitivity means that very low cone excursions are needed and hence distortion is very low and music is not muddied.
Old 24th October 2019, 05:43 AM   #568
I listen to a lot of progressive metal, Fusion and contemporary classical music. Using the FAST approach works really well
Because they are not trying to do deep bass means the drivers are not working as hard, leading to a very fast punchy sound that manages to do complex music justice.
Old 25th October 2019, 06:56 PM   #569
Thanks guys!!
Are you filtering out the lower frequencies at all? The stuff below 160hz?
-Jim
Old 25th October 2019, 07:04 PM   #570
I do not bother myself
My friend used to cut off about 150 but no longer as he has gone line array with the PRV drivers
I think if you are in a position to experiment easily then give it a go
PRV 5MR450-NDY for FAST/WAW applicationsHide this!Advertise here!
5 Most Used Applications carvercasey The Lounge 48 27th July 2017 09:24 AM
WTB: pair of PRV 5MR450-NDY guglielmope Swap Meet 1 20th May 2016 08:57 AM
How low can PRV 5MR450-NDY go sealed . Bigun Full Range 7 22nd March 2016 02:00 AM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
Copyright ©1999-2019 diyAudio
