PRV 5MR450-NDY for FAST/WAW applications
Old 20th August 2019, 03:16 PM   #551
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
That looks very nice, Gadut!
All those pro audio drivers must have some snappy slam to it.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 25th August 2019, 11:18 AM   #552
gadut is online now gadut  Indonesia
gadut's Avatar
hopefully they will slam in my house
spare some time for my hobby, from my previous plan to make 3 way (nu3000dsp + minidsp 2x4hd) become 4 way and i need to get another minidsp. I'm using beston rt002-dipole with removed waveguide as super tweeter
back support template completed, will be followed by cutting 2 layers plywood of 18mm
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 25th August 2019, 04:10 PM   #553
Got Foam?
xrk971's Avatar
Very impressive setup this will be, Gadut. Why don’t you get a 2x8 DSP? I have run two independent 2x4’s and that works too but have to program it twice.
Check out Analog Devices ADAU1452 eval board. $250 I know but very powerful SigmaDSP studio software and FIR capability. Plus you can add your own I2S input or output.
Old 26th August 2019, 02:02 AM   #554
gadut's Avatar
I had plan to use nanosharc and build my own multichannel dac but then it's too complicated for me. I decided to build 4 channel monoblock amplifier and put each 2x4HD on each amplifier box
i chose HD version due to standard 2V output, lower noise and better parts used compared non HD version. FIR is a nice feature but not my priority because i will start with Harch xo. i think duplicating config file 2x is simpler than playing with dsp encoding + i2s
i'm more to hardware man instead of software, i might still cut plywood in the next 2yrs building speaker set and room treatment
Old 8th September 2019, 12:13 PM   #555
gadut's Avatar
2nd set of minidsp 2x4hd arrived and 1 side baffle is completed. I'm ordering class d amplifier D4K5 with 90Vdc supply for subwoofer and apex B500tef for woofer.
since PRV has power rating, i might try b500tef just in case it matches with good class AB or A
Old 20th September 2019, 07:01 AM   #556
spatch is offline spatch  United Kingdom
Originally Posted by k9vap View Post
I'm thinking this might be close:
Beyma :: Beyma 5G40Nd/N PS82.76
I had the PRV drivers for about a year now and love what they do.
I recently blew a driver and ordering two replacement drivers to the UK was proving to be very expensive so Vic suggested I go for the Beyma Beyma 5G40Nd
I only had them playing for a day but I am pretty impressed. In my set up they extend better and the sound is a bit more natural. I am needing a bit more support from the bass more but this will probably improve as the system burns in
For those of us in the UK, it is a good alternative to the PRV for FAST applications
Old 20th September 2019, 11:50 AM   #557
Got Foam?
xrk971's Avatar
That Beyma looks very similar to the PRV, basket, magnet, cone, surround, terminals. Wonder if that is same OEM? Specs look very good - the 92dB is proabnoymmore conservative rating?
Beyma 5G40Nd/N - 5" 200W 8 Ohm PS82.76
Old 20th September 2019, 12:20 PM   #558
papasteack is offline papasteack  France
They're are different beast for a lot of characteristics. Voicecoil length, gap height, voicecoil wire material, qts, number of magnet, flat impedance curve of the PR wich suggest big demodulation rig(s) around the gap..., floppy suspension of the PRV (qms=22 !!).
But still similar response curves.
Old 20th September 2019, 01:43 PM   #559
I think in reality the Beyma is a bit more sensitive as I have to lower the volume control to reach the same levels
It certainly a cost effective solution that will work in a Fast based system
PRV 5MR450-NDY for FAST/WAW applicationsHide this!Advertise here!
5 Most Used Applications carvercasey The Lounge 48 27th July 2017 08:24 AM
WTB: pair of PRV 5MR450-NDY guglielmope Swap Meet 1 20th May 2016 07:57 AM
How low can PRV 5MR450-NDY go sealed . Bigun Full Range 7 22nd March 2016 01:00 AM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Copyright ©1999-2019 diyAudio
