Driver Suggestions for 7L Cabinet.
Old 15th May 2014, 04:08 PM   #11
chrisb is offline chrisb
If you know the workable dimensions of the PE enclosures, that a good look at the dimensional drawings for Alpair drivers on Mark's site. The 7 comes with a separate / optional bezel ring which adds approx 5mm diameter and 1.5mm for depth required for flush fit. I've used them both ways, and can't detect any audible difference.
Raw Drivers | Markaudio
Retired from active DIY
Old 19th May 2014, 05:41 PM   #12
prighello is offline prighello  United States
One more question, does baffle position matter much with the Alpair 7.3? I think I read something about this driver having BSC built in? Can I just center it in the baffle or should I move it towards the edge. My limited experience is with multi-ways where you are trying to account for acoustic centers and diffraction and such.
Old 19th May 2014, 06:41 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Centreing on the baffle is not a good idea. It will concentrate the baddle step/diffraction effects.Off setting the driver will spread them out.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th May 2014, 06:57 PM   #14
Of course on very narrow baffle designs - such as many of the "Ken" family or Pensils for that matter, the option to offset from centre is rather limited
Old 19th May 2014, 07:12 PM   #15
Thanks guys. I was speaking from an up/down perspective. I am quite a layman when it comes to this stuff.
Old 19th May 2014, 07:15 PM   #16
frugal-phile(tm)
planet10's Avatar
Option 2 would be preferred
dave
Old 19th May 2014, 09:10 PM   #17
dave
Okay, thank you for the input. If I do option 2 that will leave me with some room on the bottom of the baffle. Should I add a port then? I ask because I have some leftover part express adjustable ports laying around. They are 1 3/8" ID and the length can be adjusted from 4 5/16" to 8 5/8".
I know this is kind of evolving a lot but I figure I should try to get the best out of the drivers with what I have available to me. I am sending in the baffles to a CNC shop so I have a day or two to make up my mind on what I should do.
I love audio but I am just a dabbler and I have only designed one speaker system. A two way that I had a lot of help on. Thank you again for all the advice I really appreciate the help.
Old 19th May 2014, 09:25 PM   #18
frugal-phile(tm)
planet10's Avatar
Did you choose a driver?
dave
Old 19th May 2014, 09:30 PM   #19
dave
Yes, I chose the Alpair 7.3 driver. Also, does it matter how close or far the port is from the driver or the baffle edge?
Old 19th May 2014, 11:42 PM   #20
frugal-phile(tm)
planet10's Avatar
4-4.25" long
dave
Driver Suggestions for 7L Cabinet.Hide this!Advertise here!
Cabinet suggestions for two Eminence LAB12 Rullknufs Subwoofers 55 6th August 2013 11:06 AM
Focal Car Seps - Cabinet Suggestions weng Multi-Way 9 9th August 2008 04:16 PM
isophon PH2132E - cabinet suggestions? MichaelPublic Multi-Way 0 18th December 2006 02:47 AM
Cabinet varnish suggestions lmcmaju Multi-Way 3 9th September 2004 03:30 AM
Suggestions on stiffening woofer cabinet? Keith TDI Multi-Way 4 17th March 2002 06:33 PM
Copyright ©1999-2019 diyAudio
