10" full range for mini Onken
Depends on how close the speakers are to a wall and how much room gain there is.
If you want a max flat alignment to Fs, then the specs to the first approximation will be ~ Vas = 80 L, Fs = 40 Hz, Qts = 0.4
You can quickly determine if a driver is ‘in the ballpark’ with these formulas or if your math skills are better than mine, rearrange them to solve for Vas, Fs, Qts:
Vb = 20*Vas*Qts^3.3
Fb = 0.42*Fs*Qts^-0.96
GM
