Anyone try the Faital Pro 4FE32 or 3FE22?
Old 19th October 2018, 04:37 PM   #71
midrange is offline midrange  United Kingdom
Originally Posted by nskii View Post
Hi DIYers! Sorry to bring an old topic out but I'm considering buying two 4FE32s myself and I wonder with what kind of cabinet designs did you guys come up with? My use would be a use in a boombox, for outdoors obviously but I'm worried about its 0.6 Qts value since drivers with such high Qts values require large cabinets. At least to my knowledge.
Br, Nino
Well yes, it does need a large box, but only relative to it's vas. These speakers have a very small vas (2 litres). The calculator I looked at gave a net box volume of only 4.14 litres for an f3 of 67.5 Hz.
Old 20th October 2018, 08:23 AM   #72
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Here is my new 0.53x Karlsonator that uses a pair of 3FE25-16ohm in parallel. Sounds great.
Mini Karlsonator (0.53X) with Dual TC9FD's
Mini Karlsonator (0.53X) with Dual TC9FD's-jan-karlsonator-06-jpg
Mini Karlsonator (0.53X) with Dual TC9FD's-jan-karlsonator-08-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th October 2018, 05:42 PM   #73
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
What amplifier is that in the huge, foreboding, unmarked chassis?
Those look great!
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 20th October 2018, 06:50 PM   #74
Got Foam?
xrk971's Avatar
That’s a 4U Dissipante amp case from DIYA store with UMS spec pre-tapped holes on the heatsinks. I use it as a development case for my amps. The PSU and Cade are rather fixed (although PSU changes too). Currently, the Pass M2 is in there. Amps that have been mounted in there so far include: Pass Aleph J, Zen Mod’s Babelfish J, Alpha 20, Apex FX8 Bimo mod biased to Class A, and Pass M2.
Anyone try the Faital Pro 4FE32 or 3FE22?Hide this!Advertise here!
Faital Pro HF10AK csuflyboy Multi-Way 7 13th December 2013 07:48 AM
Faital Pro 3FE22 - 4 ohm roubi Full Range 15 21st August 2013 12:26 AM
horn for Faital Pro HF200 oldies Multi-Way 1 9th February 2013 01:14 PM
Faital Pro in Audio Show CLS Everything Else 4 6th October 2012 07:59 PM
New Faital Pro 6PR150? djlivex Multi-Way 3 16th January 2010 03:28 PM
