Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
Old 11th January 2016, 07:40 PM   #491
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by kevner1954 View Post
so can you use a alpair 7 in the XL cabinet?????????????
You could but performance will not be as good as in FH Mk3 (probably downright poor). Mk3 is originally optimized for A7.x
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th January 2016, 07:50 PM   #492
chrisb is offline chrisb
Beat me tuit - a correct answer might be - " sure it'd 'work' in the most technical sense" but definitely not optimally. I'd imagine the difference in the tuning and mass loading on the two sizes of drivers would be sufficient to allow the A7 to be overdriven at higher SPLs? Dr Lindgren could probably describe that in more detail.
Technology honors no Hippocratic oath
Old 12th January 2016, 02:41 AM   #493
kevner1954 is offline kevner1954  United States
you know there is a couple people out there that would have asked because it seems you like the alpair 7 more than the 10. the best question is "why would you want to?" Thanks
Old 12th January 2016, 03:02 AM   #494
frugal-phile(tm)
planet10's Avatar
For absolute fidelity yes. But with the new A10s the differences are small enuff, and in the small detail, that it can easily be buried before the signal gets out of the amplifier, in which case the extra bass elevates the A10s. Or if the extra bass is more important to you than the small detail.
All 3 drivers are very good. And do note that an A10.3eN or A10PeN out-details a stock A7.3. And that the A7 and A10 MOAPs are wild cards, and very very good.
FH3 is optimal for A7.x, FHXL for the A10s. And an optimal box is important.
dave
Old 12th January 2016, 11:42 AM   #495
Thanks Dave most noteworthy as usual
Old 12th January 2016, 02:41 PM   #496
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
What Dave & Chris said. While it's theoretically possible if the box is then over-damped, you would gain nothing by doing so, and sacrifice performance without anything in return. So strong advice is to stick to the appropriate sized enclosure.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 23rd January 2016, 05:13 PM   #497
I made a donation to Diyaudio , how do I get the plans for the XL
Old 23rd January 2016, 06:38 PM   #498
frugal-phile(tm)
planet10's Avatar
Send a copy to me via email and i'll get you the link.
dave
Note: plans were updated 160116. Anyone with the older link will find it will break.
Old 24th January 2016, 05:50 AM   #499
SCD is offline SCD  Canada
hello dave;
Were there significant design changes in the latest version. I am just about to glue a set and still have an option for changing them.
SCD
Old 24th January 2016, 05:51 AM   #500
frugal-phile(tm)
planet10's Avatar
I added some cut-plans
dave
Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, moreHide this!Advertise here!
Pensils for Alpair 10.3 & Alpair 10p planet10 Full Range 226 29th December 2019 01:18 AM
Frugel-horn XL driver? ColinA Full Range 16 23rd October 2018 06:09 AM
Frugel-Horn XL for Fostex Fe 168eZ pehajope Full Range 39 25th January 2016 03:49 PM
Frugel-horn XL build falcoron Full Range 5 17th December 2014 06:23 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
