Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
Thread Tools
Old 18th June 2021, 01:06 AM   #1511
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Excellent! Thanks for checking.
XRKaudio Store // Manufacturer’s Forum
Old 18th June 2021, 01:43 AM   #1512
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by Scottmoose View Post
TB W5-2143
Old 18th June 2021, 07:21 AM   #1513
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Not a problem. I really should have checked that unit before.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 18th June 2021, 12:47 PM   #1514
Got Foam?
xrk971's Avatar
It’s one of my favorite full range drivers. It’s got a great bass punch and decent highs. Relatively smooth response. Well built cast frame and looks good.
Old 18th June 2021, 01:17 PM   #1515
Scottmoose's Avatar
Good to know, I've had half an eye on that series for a while. If TB have got the QA / QC consistency right, they look like nice options to me. Out of interest, did you take any data on them -if so, how did it line up to the published (accepting some variation through different drive levels)?
Old 18th June 2021, 02:05 PM   #1516
Got Foam?
xrk971's Avatar
The T/S parameters are very close to published. The usual QTs is always a bit higher than published but that happens to almost every brand except Dayton. They never exaggerate their QTs. Frequency response matches published. Smooth and flat. Reach is surprisingly high. It’s an overlooked driver that deserves more attention.
Old 18th June 2021, 03:30 PM   #1517
Scottmoose's Avatar
Good to know, many thanks.
I suspect Dayton's T/S data (I've found roughly the same) shows good consistency to most home measures because they publish with specs. taken with DATS and Omnimic, which at least ensures that it's similar to the gear a majority of DIYers have access to. Contrast to a majority that tend to publish data with higher voltage drives, which almost guarantees a significant deviation due to the altered techniques / conditions.
Old 29th June 2021, 11:12 PM   #1518
Rated is offline Rated
Lots of great praise for the FHXL and alpair drivers. Can someone describe the sound characteristics of this combination?
Old 30th June 2021, 01:42 AM   #1519
frugal-phile(tm)
planet10's Avatar
Good :^)
Really good if you have the support gear.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 11th August 2021, 10:35 AM   #1520
luigiman is offline luigiman  United Kingdom
luigiman's Avatar
Re the TB W5-2143, based on the factory data it'll work fine; double checked & spec. is well within the intended loading range so should be a good combination.
Hi Scott, just interested: the plans for the FH MK3 say that most 4-5in drivers would work well, so would the W5-2143 work in the MK3? Or do you not recommend this?
Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, moreHide this!Advertise here!
Thread Tools
Pensils for Alpair 10.3 & Alpair 10p planet10 Full Range 236 22nd August 2020 07:20 PM
Frugel-horn XL driver? ColinA Full Range 16 23rd October 2018 05:09 AM
Frugel-Horn XL for Fostex Fe 168eZ pehajope Full Range 39 25th January 2016 02:49 PM
Frugel-horn XL build falcoron Full Range 5 17th December 2014 05:23 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
