Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
Old 18th May 2019, 06:05 AM   #1231
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Yes it is OK. You might just want to screen off the choke. Easier and much less material needed.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th June 2019, 06:52 PM   #1232
Eric is offline Eric  United States
Eric's Avatar
Just another note to comment on how much I'm enjoying this awesome speaker design. I switched a few components around the other day and was able to listen to a nearly 100% DIY playback chain: It consists of a heavily modified Technics SL-1200 TT which feeds a Pearl2 phono stage, and a B1 Korg NuTube preamp that drives Mike's MoFo amp and ends at the FHXL with 10.3 drivers.
The MoFo amp seems to produce a bit more bass than other amps (this probably has something with having lots of iron in the signal path...). This combination just sounds awesome to my ears! I was listening to Pink Floyd's The Wall and just couldn't get over how pleased I was. The NuTube and MoFo generate a bit of 2nd order harmonics and provide a nice blend of a spacious sound stage as well as a believable center image for vocals. The horns and the MoFo combination really generate a surprising amount of bass for such a relatively small driver!
What fun! The NuTube and MoFo combination don't provide a ton of gain (about 15dB) but it's certainly more than enough to enjoy and both also fit the "frugal" spirit of the speakers. My MoFo amp was constructed with mostly recycled/scavanged parts, so the overall bang for the buck of the NuTube/MoFo/FHXL is into the stratosphere!
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 11th June 2019, 08:07 PM   #1233
zman01 is offline zman01  Bangladesh
Eric,
Good to hear that your current system has excellent synergy - enjoy!
Old 12th June 2019, 12:30 AM   #1234
chrisb is offline chrisb
Eric, if you’re a Floyd fan try Wish You Were Here - one of those albums from which I find it almost impossible to excerpt a single track.
Retired from active DIY
Old 12th June 2019, 01:50 AM   #1235
Eric's Avatar
Chris, I'll have to look for a copy, thanks for the recommendation. Need to find some time to go through the "A list" of albums again...
Old 12th June 2019, 07:23 AM   #1236
Don’t you just love it when any new piece of gear makes you dig through your decades old collection of various media formats in the attempt to plumb for previously undiscovered depths of inner detail? Of course the finding of those is often a textbook example of expectation / confirmation bias - but no one is getting hurt, so I’m good with that.
For some reason this got me reminiscing about over 50yrs of listening - a lot of fond memories, even with sub par systems.
Old 12th June 2019, 01:52 PM   #1237
Eric's Avatar
Yep, confirmation bias at its finest . But, it's also a fun way to relax!
Trackhappy: Somehow I missed this before, but that is one serious DIY effort! WOW! I guess either way, our DIY hobbies can kill us if we screw up too much...
Old 12th June 2019, 08:30 PM   #1238
mp9 is offline mp9  United States
So what's the consensus on FHXL utilizing the MA 11MS versus the MA 10p which FHXL was designed around?
I like the "BBC curve" of that MA 11MS only hesitant about driving the 88db 11MS with my 3wpc 2A3 SET amp. I could set it up in a small'ish listening room which actually would be better for corner loading the FHXL. However, doing so may not allow for proper listening distances short of a seating position against the rear wall. I'd guess the MA A10p would do better on 3wpc but hard to get excited about it after the whole A12p thing. I still have the old HH Scott 222c 18wpc PP tube int amp to drive the MA 11MS so not a total write off if the little SET can cut it, only I still prefer the sound of the little 3wpc SET, could just be better to save the money for something else?
Old 12th June 2019, 08:34 PM   #1239
silasmellor is offline silasmellor  Denmark
The efficiency is only about 1 db different between A11ms and A10p, would that really be so much easier to drive from a 3W amp? My limited experience with the Alpairs is they are cheap enough (even factoring the wood and work for building enclosures) that taking a plunge and trying them isn't going to ruin you.
Old 12th June 2019, 10:22 PM   #1240
IIRC, @chris-planet10 team have said 10p is actually more efficient than the numerical spec on paper and only about a db less than the 91.7dB A12p.
WRT cost, the project is not so cheap if I purchase the CNC cut FHXL flat pack. Although, after seeing the build pix in post #1224 by @Trackhappy, FHXL looks rather simple to build from scratch so no real need for me to pay a premium for a flatpack...
Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, moreHide this!Advertise here!
Pensils for Alpair 10.3 & Alpair 10p planet10 Full Range 220 29th July 2019 03:26 AM
Frugel-horn XL driver? ColinA Full Range 16 23rd October 2018 06:09 AM
Frugel-Horn XL for Fostex Fe 168eZ pehajope Full Range 39 25th January 2016 03:49 PM
Frugel-horn XL build falcoron Full Range 5 17th December 2014 06:23 PM
Copyright ©1999-2019 diyAudio
