Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
Old 15th March 2019, 05:41 PM   #1121
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A11ms drops right in. As always besides the driver — which nominally should be damped similar to A10 — room, room placement, and user taste play a role in the amount of damping under the driver.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th March 2019, 02:11 AM   #1122
GASCo is offline GASCo  United States
GASCo's Avatar
Originally Posted by Attaris View Post
It's very refreshing to see a welcoming community. Now, since I've been encouraged to ask questions - here's a few:
Do XL plans need any modifications for a pair of 11MS drivers? I figured stock ones would be fine but better safe than sorry.
I find it hard to come by any wool felt here. What other decent options do I have for damping?
Thanks!
Denim insulation (the thinner compact stuff) is an acceptable replacement for wool iirc
Old 17th March 2019, 03:52 PM   #1123
Spica is offline Spica  Canada
Hi. Perhaps this is bad timing considering Dave's upcoming hospital stay. I would like the plans for the FHXL if possible. Tried to send an email,but couldn't figure it out. I have made the donation--actually for the second time, but I can't find the file. Sorry for the bother.
Dave,all the best to you,I've had a number of hospital visits.
Old 18th March 2019, 04:06 PM   #1124
Got it.Thanks Dave. Much appreciated
Old 18th March 2019, 09:05 PM   #1125
bfg4wd is offline bfg4wd  United States
Default terminal cup
Got all the panels cut out of 3/4BB ply, now I'm cutting the opening for the driver. Was about to cut a hole in the back panel for a terminal cup, but looking at how thin the plastic is, I'm afraid this will affect the rear chamber area.
Any advice, or experiences with this?
Ted
Old 18th March 2019, 09:10 PM   #1126
frugal-phile(tm)
planet10's Avatar
it will not be an issue as long as it is sealed.
dave
Old 18th March 2019, 10:30 PM   #1127
chrisb is offline chrisb
I don’t think Dave meant that the enclosure needs to be a sealed type, just that the mounting of the terminal cup is air-tight. Most of them come with quite sufficient closed cell foam baskets for that purpose.
Retired from active DIY
Old 20th March 2019, 08:54 PM   #1128
kevner1954 is online now kevner1954  United States
11ms just came on for sale, woo hoo
Old 20th March 2019, 09:03 PM   #1129
frugal-phile(tm)
planet10's Avatar
I got mine yestesterday, 24 of each (11ms/7ms).
Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more-mad-190319-jpg
dave
Old 20th March 2019, 10:31 PM   #1130
That’s a whole lot of good sound there dot dot dash!!!
Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, moreHide this!Advertise here!
Pensils for Alpair 10.3 & Alpair 10p planet10 Full Range 198 21st February 2019 09:32 PM
Frugel-horn XL driver? ColinA Full Range 16 23rd October 2018 05:09 AM
Frugel-Horn XL for Fostex Fe 168eZ pehajope Full Range 39 25th January 2016 02:49 PM
Frugel-horn XL build falcoron Full Range 5 17th December 2014 05:23 PM
Copyright ©1999-2019 diyAudio
