Hi folks,
My friend is interested in creating a few speaker boxes to go on his bicycle. He is fabricating the boxes out of sheet metal, so the boxes themselves are waterproof. However, he was thinking about just letting the face of the speaker sit open in the air. I told him that we would have to find some way to prevent water (rain or otherwise) from hitting the cones, otherwise the speaker cones would start to disintegrate pretty fast. I was thinking even the rubber ones wouldn't do so well.
Do I need to get marine speakers for such an application? Or something else? Thanks!
That, or the treated ones used in large motorcycle sound systems: https://www.google.com/search?q=hod...=honda+goldwing+replacement+speakers&tbm=shop
GM
GM
You have to look at drivers with special treatment, with weather proofing only, for eg, outdoors. Almost all manufacturers have them.
For very harsh conditions, like going the "underwater" type that are more resistant, for nautical use etc, look at waterproof then.
Visaton FR16WP-4 Outdoor 6.5" Full-Range Waterproof Speaker 4 Ohm White (pic)
Waterproof Speakers
HowStuffWorks "How Weatherproof Speakers Work"
Amazon.com: EasyAcc CSR Bluetooth Speakers with Built-in microphone -Support USB Flash & SD Card Playing, Mini Outdoor Sports Portable Wireless Speakers for Samsung Galaxy S4 S3 Tab 3 2 Note 2 3, Nexus 7 10, iPhone 5S 5C 4S, iPad 4 3 Mini, Nokia 925
Dual LU43PB 4" 3-Way Indoor/Outdoor Speaker Pair Black 267-569
N5R :: DC Gold Audio ::
Speakers | Integrated and mountable Transducers | Farnell United Kingdom | Results
Visaton In Stock At Parts Express With Free Shipping
Waterproof Speakers
FWIW basically no. Plastic coned and surrounded drivers will
be fine. Many car speakers will be suitable in sealed boxes,
but go for dual cones not coaxials (they are not sealed).
Dash, Door & Deck Car Speakers in the Car Audio Department at Parts Express | 390 - 25423|4135
rgds, sreten.
Your friend is about to find out how onerous the physics
of small drivers in open air is compared to in a room.
For music on the move open headphones / earphones
are far more effective than speakers on a bycycle.
rgds, sreten.
We are totally fine with going with larger speakers as well. Weight isn't too much of a factor, since this will be a cargo bike anyway. Maybe some midrange speakers and some subs. What do you think would work the best?
Since we live in the pacfic NW, it rains quite often, so I wanted to be absolutely sure that plastic speakers will work even if they are gonna be soaking wet and 40 degrees F 90% of the time. What about rubber for that matter? Thanks!
What will work best depends on a lot of things, not least
a realistic understanding of what is possible, and within
that remit going for a solution best suited to your wants.
If your wants and needs are unrealistic, there is no solution.
Whatever you build its going to be very compromised due to
the application, and getting the right compromises matters.
No details of whatever is supposed to drive the speakers.
rgds, sreten.
rgds, sreten.
We are going to use a car receiver to drive the midrange speakers, probably some random receiver from goodwill or similar.
The receiver will probably be around 50 watts peak (like many random car receivers I have seen) although more power would be nice. The receiver will need to have sub output of course.
Probably going to use a car audio power amp to drive the subs.
If you have any suggestions, I would be glad to hear them as well. Cheers!
I'd have lots of suggestions, but I'm not clairvoyant.
rgds, sreten.
Ahh ok I don't need a suggestion for a specific speaker, I just need to know if there are any general brands, types, or series of speakers that will withstand continual rain and cold weather. That's all. I can make the audio specific decisions from there. Thanks
I just googled a brand of speaker that I used for car audio back in the day...
Babb Speakers, they were a single drive and were waterproof and sounded pretty good from my memory.
Babb Speakers :: DC Gold Audio ::
It looks like Babb was bought by DC Gold Audio and have similar type products.
Home :: DC Gold Audio ::
- Full Range
- Waterproof speakers?
