The making of: The Two Towers (a 25 driver Full Range line array)
Old 8th December 2019, 10:21 AM   #5501
Halair is offline Halair  Norway
Thunder
Old 8th December 2019, 11:30 AM   #5502
wesayso is online now wesayso  Netherlands
wesayso's Avatar
Thanks for the positive feedback guys! Much appreciated.
I won't make any decisions about processing until I see what they do in a measurement. Though I will say that I'm hoping to shave off about 6 dB of the array's bottom end, while keeping them mostly full range and make up for that with the subs. The goal is to get more uniform balance left to right down to an even lower frequency. Right now that balance is made by shifting energy in the arrays below about 80 Hz. I'm hoping to make up for that with the subs instead.
I still have to see measurements first to know how high in frequency these subs can support the arrays. As long as they are down far enough by ~900 Hz, whose 3rd harmonic is responsible for that nasty peak at ~2700 Hz. So in theory they can run up to about ~200 Hz as helper woofers for the arrays.
Use Science to design your speakers and they will sound like a piece of Art...
Old 9th December 2019, 06:43 PM   #5503
wesayso's Avatar
Some more inner details I've been working on.
As mentioned a bit earlier in this thread, the inner walls of the enclosure have been covered with MLV.
The making of: The Two Towers (a 25 driver Full Range line array)-mlvwalls-jpg
Making all the walls approximately one Inch in thickness...
The aluminium box, protecting the amplifier also got a cover-up with MLV:
The making of: The Two Towers (a 25 driver Full Range line array)-eindcap-jpg
The speaker-out are in place as well as a ground connection (not seen here).
The way it looked before:
The making of: The Two Towers (a 25 driver Full Range line array)-jpg
And finally a detail of the protection screen, as seen from the inside:
The making of: The Two Towers (a 25 driver Full Range line array)-detail-jpg
Hardly visible, the screen is sunk into the baffle by a couple of mm and glued in place.
The same rubbery glue was used to seal off the corners of the aluminium cover.
Almost ready to start impedance measurements. Sadly I ran out of time as the old laptop wouldn't work with me today. That's a job for next weekend.
Then on to finishing the amplifier connections etc...
I did say I would take my time .
The making of: The Two Towers (a 25 driver Full Range line array)Hide this!Advertise here!
Full range line array inrank Full Range 43 16th November 2017 08:25 AM
Full range line array in a tube carpenter Full Range 44 7th January 2014 03:19 PM
full range driver bipole line array idea. fazman Multi-Way 2 7th January 2006 04:36 PM
full range driver bipole line array idea. fazman Full Range 1 6th January 2006 12:21 PM
Full-range line array? mazeroth Full Range 20 1st November 2004 04:47 PM
Copyright ©1999-2019 diyAudio
