Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#4051 |
Hi X, I think you once calculated, or guestimated, 94dB or was it 96dB? for parallel 16Ohm 3FE25's.
B1, ACA, AKSA Lender Pre, H2 V1, Dual 3FE25-16 0.53X Karlsonators |
#4052 |
Thanks for posting those.
They look wonderful. Inspiring. I just received my delivery of foam board for my first crack in a couple of weeks time. |
#4053 |
Got Foam?
I calculated 96dB based on 90dB at 2.83v. But it seems the spec I used was misquoted by Parts Express. Sorry about that, I should have been more careful and looked at the factory data sheet.
1W into 16ohms requires 4v as power is V^2/R. So the spec is 90dB at 4V and 1m. Two in parallel is +6dB and 2.83v is -3dB from 4v. So net gain is 3dB for dual 3FE25-16 in parallel. Or 93dB at 2.83v and 1m and 8ohms.
XRKaudio https://www.etsy.com/shop/XRKAudio |
#4054 |
Thanks for correcting the calculation.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Dual PAM8320 Mini Amp Build | vfxsoup | Class D | 4 | 18th October 2020 06:35 PM |
Have 120 of NOS National Semiconductor NPD5566 Dual JFET in mini-DIP 8-pin packaging | AudioMaker | Swap Meet | 1 | 12th September 2019 05:30 AM |
mini Dual HS-37 - but platter does not turn | Karl vd Berg | Analogue Source | 3 | 7th April 2014 07:50 PM |
Mac Mini dual DAC crossover | OzMikeH | Digital Line Level | 2 | 12th January 2009 11:11 PM |
Dual hi-vi mini project | BionicSniper | Multi-Way | 23 | 7th August 2008 05:06 PM |
New To Site? | Need Help? |
