Mini Karlsonator (0.53X) with Dual TC9FD's
Mini Karlsonator (0.53X) with Dual TC9FD's Please consider donating to help us continue to serve you.
Old 21st January 2020, 06:50 PM   #3651
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
If you want to add some baffle step compensation (BSC) to reduce the highs and increase the bass perception. Use 1mH for 8ohms and 0.5mH for 4ohm speakers. Parallel that with 2.2ohms, 3.3ohms, 4.7ohms, or 6.8ohms. Adjust to taste. In general, Karlsonators make so much bass relative to a bass reflex you don’t need a BSC or any filter.
0.1mH isn’t going to do much but attenuate your highs above 10kHz.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st January 2020, 07:50 PM   #3652
Skylar88 is offline Skylar88  South Africa
Originally Posted by xrk971 View Post
0.1mH isnít going to do much but attenuate your highs above 10kHz.
That's exactly what I found I needed with dual 3FE25's, but I chucked the BSC and now use software EQ. MiniDSP would be even better.
B1, ACA, AKSA Lender Pre, H2 V1, Dual 3FE25-16 0.53X Karlsonators
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 04:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 01:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 05:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
