Mini Karlsonator (0.53X) with Dual TC9FD's
Old 8th September 2019, 02:15 AM   #3431
moray james is offline moray james  Canada
Originally Posted by xrk971 View Post
More here:
Basotect for damping BR-cabinet?!
Use melamine foam. Same as Magic eraser cleaning pads. 100 from China for $7.
Thanks a lot.
moray james
Old 8th September 2019, 02:32 AM   #3432
soundaddict is offline soundaddict  Canada
A small dome tweeter above aperture vertex for a cyclops look works too.
I really appreciate it, thank you
Old 8th September 2019, 03:18 AM   #3433
freddi is offline freddi  United States
freddi's Avatar
song for your k'nators YouTube
Old 8th September 2019, 05:39 AM   #3434
daturat100r is offline daturat100r  New Zealand
Made a start on a pair 0.4 Karlsonators,drew up scale drawing a few weeks ago and cut out inner workings from leftover scraps of Meranti marine ply .Raided wood rack and found some 12" wide 3/8" dressed Kauri sarking that came out of a 100+ year old villa when i cut a hole for a window ,machined it up perhaps 15 years ago so at least its well seasoned.Good use for it cutting thru nail lines so only odd scrim tack hole will show.
Cut sides rough to length and marked out the inner rebates so baffles set a few mm into each side still deciding whether or not to make them "corner" cabinets,will do rebating then decide
Old 10th September 2019, 02:35 AM   #3435
I bought other 2 Radio shack 40-1197 drivers, so now I have 4 in total.Does anyone know if I can put 2 of them in parallel in 0.53X Karlsonator, would that work, please?
Old 12th September 2019, 02:25 AM   #3436
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
If you use the search function in this thread and type “1197”, you will get lots of hits. But here is the 1197 Karlsonator build and test and measurements.
Sims and plans here:
https://www.diyaudio.com/forums/atta...-freq-0.5m.png
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th September 2019, 01:56 PM   #3437
Thank you, it was this post that made me buy my first two 40-1197.Looks like one in 0.4/0.53 box can replace a CHN-70 which is a 4" too, good hint for a noob like me.At the same time I did not find any info on dual 40-1197 in the same enclosure.I do not know if 40-1197 is too big for its size and specs to put two of them in a 0.53x box. It is bigger than TC9 FD and specs differ
Old 12th September 2019, 04:32 PM   #3438
Got Foam?
xrk971's Avatar
It will require a bigger box than 0.53x. Basically, the volume will have to double. Would require a simulation which I can't do at the moment.
The design for the 1197 (or FE103) is 0.44x in height and depth and 0.55x in width.
Basic (within 1/4in) original 1.0x Karlsonator inside dimensions are:
29.5H x 15W x 16D. Scaled by 0.44x in H and D gets: 13H x 7D x 8.25W.
In order to fit two of them in a dual, need to add about 4 in height to make room for angled bezel.
So H is 17in, let's make W same at 8.25in, now calc D to get double volume of 1st.
V1=13x7x8.25=751 cu in.
V2=17xDx8.25=1500cu in, solve for D.
D=10.6in
So scaling is H is 0.58x, W is 0.55x, D is 0.66x. Kind of a tall and skinny box. This is all done assuming box scales with doubling volume and making baffle big enough for drivers.
You could play with reduced depth and wider baffle for a more "normal" look. Try 0.60x for all dimensions.
D=9.5in x W=9in x H=17.7in is 1513cu in.
So looks like a 0.60x scaled Karlsonator should look like a normal Karlsonator and be able to play two 1197's well.
Old 12th September 2019, 10:36 PM   #3439
D=10.6in
I wouldn't mind cutting the width to 6 inches...that will require a H=26.55" keeping the same depth.I know it changes the ratio between sides, though.Is it too stupid to build it like that?
Last edited by soundaddict; 12th September 2019 at 10:50 PM. Reason: calculation error
Old 13th September 2019, 12:03 PM   #3440
Got Foam?
xrk971's Avatar
A narrower front can work. Be careful the aperture doesn’t constrict the driver cone too much or the highs may be reduced. 26in tall is kind of too tall IMO, but that may actually give you deeper bass since TL length is substantially longer. Don’t know until I simulate it.
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 04:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 01:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 05:06 PM
Copyright ©1999-2019 diyAudio
