Mini Karlsonator (0.53X) with Dual TC9FD's
Old 23rd June 2019, 03:57 PM   #3341
baswamin is offline baswamin  India
Hello XRK,
It sounds very good. For a desktop speaker, it is really awesome. It plays all genres of music pretty well. It is being driven by Allo Boss DAC on RPI and class D amplifier. I hope my nephew likes it.
Balaji
Old 23rd June 2019, 06:05 PM   #3342
jhofland is offline jhofland  United States
Default Karlsonator 0.53's in wood
Hi Folks,
X has mentioned that more than one interested party would like to see some construction plans for a wood version. These plans were developed using Sketchup 2017, so it will require some familiarity with that tool to be able to pull out individual components and measure for size and the various angles. All components are 1/2" baltic birch except the front aperture, which is 3/8.
Old 23rd June 2019, 06:35 PM   #3343
Skylar88 is offline Skylar88  South Africa
Thanks Jhofland. Much appreciated.
Old 24th June 2019, 08:35 AM   #3344
Originally Posted by jhofland View Post
...These plans were developed using Sketchup 2017
Could you "down save" the model to Sketchup 2014, please?
Old 24th June 2019, 11:09 AM   #3345
Default Karlsonator in wood_2014
Here's the same plan saved as a Sketchup 2014 file.
Old 24th June 2019, 11:21 AM   #3346
Thank you very much!
Old 25th June 2019, 02:56 PM   #3347
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Thank you Jan for providing the nice Sketchup plans for the community. It will helps many builders make perfect cabinets I’m sure.
For interested builders:
It’s important to follow the guidelines for adding melamine damping sponges and a sheet of foam core on the inside of the aperture for this speaker to sound great in wood. Don’t skip the damping pads step and try to ascertain sound quality.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 26th June 2019, 12:04 AM   #3348
freddi is offline freddi  United States
freddi's Avatar
hi X- would you give a look and opinion on Mr. Flexy's YouTube "Mini Karlsonator" ? - here's my post - I may not have the specs quite right by eyeballing but assuming the speaker works (?) then something must go on beyond the standard 6th order series BP model
Karlson secrets
Old 26th June 2019, 12:26 AM   #3349
Got Foam?
xrk971's Avatar
Hi Freddy,
Looks like an XKi without an angled front chamber board. The vent looks a bit too large so perhaps the driver has a weak motor? Hard to say how it performs until I simulate it and without TS, sort of pointless. My guess is that the vent is to large (or short) and the front chamber too square. You will get a boxy resonance. Unless the thing is meant to work under 100Hz in which case, a Karlson aperture is not needed.
Old 26th June 2019, 01:27 AM   #3350
freddi's Avatar
probably not worth your time - maybe at one of the Thai forums there's a real build (?) - ah - it does look better with a weaker motor cheap Rockville 18" but I have a hard time believing qts is that low on that speaker. even if Le is high. The magnet structure is listed as "109 oz" so maybe a 50 ounce ferrite slug
https://www.rockvilleaudio.com/RVW1800P4/
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 03:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 12:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
Copyright ©1999-2019 diyAudio
