Mini Karlsonator (0.53X) with Dual TC9FD's
Old 8th January 2019, 08:13 PM   #3171
drpro is offline drpro  United States
It's like those gumball machines, put a coin in and receive a piece.
I must build. Pass F4s, F6, M2, BA-3 preamp, MoFo, ImPasse preamp, Whammy headamp, Aksa's Lender preamp, Salas DCG3 headphone/preamp, XRK971 PCA & DCA headamp Bruno Putzey's balanced preamp, Doug Self preamp, Pete Millet Korg headamp.
Old 12th January 2019, 04:26 PM   #3172
steefdebruijn is offline steefdebruijn  Netherlands
Planning to build a wooden MiniK with dual TC9FD. Was planning to use the CAD drawing from the first post using the "original, scaled by x.53" measurements. It uses 10(.1) mm wooden panels, which I can not obtain in ply here but in MDF I can.
Questions:
- Is it wise to use the original scaled model for this?
- Is it wise to use MDF instead of the normally used ply?
- Are braces necessary with the wooden version and/or especially the 10mm panel version?
I suppose I have to play with the damping material, using the hints from xrk as a starting point.
I am planning to power each driver separately (so I can use both channels of a mini class D stereo amp fed with two mono inputs).
Steef
Old 12th January 2019, 04:48 PM   #3173
Buehgemeiste is offline Buehgemeiste
imo mdf is fine.
it is easier to cut, but not as durable and good looking as plywood.
i'm happy with my 0.9mm ply x.53's and i used the braces and i think it was the orignal scaled model.
Old 12th January 2019, 06:02 PM   #3174
tristanc is offline tristanc  United Kingdom
Originally Posted by twocents View Post
I think you have put in toooo much damping. Especially at the top. Looks like the damping is blocking the vent at the top. If possible, try and remove this to see if the bass improves?
Originally Posted by xrk971 View Post
There is some adjustment possible of stuffing via driver cutout. You can also perform surgery with xacto after assembly. Cut small window and replace and glue back on later.
Originally Posted by tristanc View Post
This is probably what Iíll have to do - totally failed in removing the foam from the top panel through the aperture... I may also cover the surgical hole and edges with sticky backed plastic to ensure a seal.
The results of my surgery... I made a square incision to the top panel, removed the foam as suggested and re-attached the square panel. Then I covered with stick backed plastic.
It has made a difference, although not a massive improvement. It is most likely the tiny output transformers, so I've another pair on the way which should have higher bandwidth.
Old 12th January 2019, 07:51 PM   #3175
9mm, not 0.9mm
Old 12th January 2019, 10:30 PM   #3176
Originally Posted by Buehgemeiste View Post
9mm, not 0.9mm
Yeah I guessed that LOL. Considering 9mm ply then too. Where the braces necessary for the stiffness or the sonics, or did you throw them in just because?
Old 13th January 2019, 12:11 AM   #3177
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
When building out of wood make sure you add melamine foam on the interior on all surfaces in line of sight contact with rear cone. I added a layer of foam core to the inside of my K aperture and melamine foam on the sides of the front chamber.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 13th January 2019, 08:46 PM   #3178
0.9mm would have been interesting.
very lightweight.
i didn't try without braces.
They seemed to make sense....
Old 14th January 2019, 10:31 PM   #3179
henrylarsen is offline henrylarsen  Denmark
Just finished my first .53X set with two Faitalpro's. First tests - with my red king class a tube amplifier is quite amazing - I have not tried karlsons before, and they really shine in their way of just engaging with the music and the room. I first tried my little Denon amplifier, but a good amplifier really seems to make a difference on this really cheap loudspeakers. I used Muddjesters nice score-andfolds plan, with a slight modification to make room for the faitals in the bottom.
I ordered two more Faitals to prepare for a set of the small ones ..
Old 15th January 2019, 05:15 AM   #3180
Got Foam?
xrk971's Avatar
Very nice work HernyLarsen! Another happy builder of mini Karlsonators.
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 04:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 01:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 05:06 PM
Copyright ©1999-2019 diyAudio
