Mini Karlsonator (0.53X) with Dual TC9FD's
Old 21st August 2018, 02:38 PM   #2851
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Originally Posted by xrk971 View Post
There is a sim for A10.2, probably close enough. Looks like it should work with 0.47x scale.
Great. Please again confirm reference or link for full size
"x"
Thanks a milion for your time.
JC
Old 21st August 2018, 04:14 PM   #2852
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
"x"
The original design for the Karlsonator was made by GregB - so, a huge thanks goes out to him for the big one that started it all.
The full scale 1.0x plans are linked on post #1, but is below for convenience:
https://lh3.googleusercontent.com/-I...arlsonator.png
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st August 2018, 04:31 PM   #2853
mga2009 is offline mga2009
what driver size is recommended for the full karlsonator?
is there any recommended driver?
i assume it needs a full range driver, or maybe a coaxial one.
Old 21st August 2018, 05:29 PM   #2854
JC Fardo's Avatar
Eminence Beta LTA 12
JC
Old 21st August 2018, 05:45 PM   #2855
Got Foam?
xrk971's Avatar
Freddi would have some good recommendations. I have simulated a Beta 12CX and that works well. You need a XO though for coaxial.
Old 21st August 2018, 06:00 PM   #2856
well, here in my country we do not have access to coaxials mor 12" fr speakers so...
the 0.4x and 0.53x are the ones to go...
which is the bigger dual drive i could fit in the 0.53x?? dual 4"???
Old 21st August 2018, 08:17 PM   #2857
Got Foam?
xrk971's Avatar
The preferred and tested design is either a dual 3FE25-16ohms in parallel for the 0.53x or a single Dayton PA130-8.
I don’t know of any 4in drivers that can be used in dual 0.53x without me running yet another simulation. I would imagine dual 4FE32 could work but it’s a guess.
Old 23rd August 2018, 05:19 AM   #2858
baswamin is offline baswamin  India
X,
Have you simmed 0.4x Karlsonator for Viston B80 and will it work fine ?
Old 23rd August 2018, 08:02 AM   #2859
Skylar88 is offline Skylar88  South Africa
@xrk971
I've drawn my own plans for the 0.53 Karlsonator with dual 3FE25-16's for A1 size 5mm foam core board.
See PDF files below.
NB: the baffles are 202mm wide (internal width of the speaker cabinet).
Old 23rd August 2018, 08:48 AM   #2860
If using LitePly driver boards, use the baffle drawing below.
4x A1 sheets are needed for two speakers.
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 03:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 12:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
Copyright ©1999-2019 diyAudio
