Mini Karlsonator (0.53X) with Dual TC9FD's
Old 18th June 2017, 10:12 PM   #2021
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
K aperture will smooth polar so that beaming is very minor effect. The aperture forms an acoustic lens.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th June 2017, 01:30 AM   #2022
Got Foam?
xrk971's Avatar
Originally Posted by EmuMannen View Post
You are right, not only a zero too many but also a missing five. Correct scaling factors:
  • H: 0.5979
  • W: 0.5370
  • D: 0.5282
Any luck with he build yet?
Old 20th June 2017, 06:23 AM   #2023
EmuMannen is offline EmuMannen  Sweden
No not yet. Vacation in a couple of weeks. Hopefully get the time to clean out the shop and build a couple. But I am intrigued by several projects right now. I would also like to try the W5-2143 in a Decware DNA Horn.
Biggest problem though, a wife "get rid of at least a pair before you build anything new" embargo in full swing...
Old 20th June 2017, 01:01 PM   #2024
Got Foam?
xrk971's Avatar
I have a detailed Akabak model of DNA I should simulate it.
Decware DNA Horn
SWMBO's Second Law of conservation of audio...
Old 20th June 2017, 02:35 PM   #2025
zman01 is offline zman01  Bangladesh
Resistance is futile!
Old 20th June 2017, 05:00 PM   #2026
boswald is offline boswald  United States
This is why you need a stash of junk speakers(take out the one good part you got it for)!
Old 21st June 2017, 05:45 PM   #2027
That would be really cool. I am playing with the idea of flipping them 90 degrees making them side venting with a wider baffle. I am also playing with the idea of putting two drivers on that wide baffle (looks like there could be enough room). I might even make a foam board prototype just to get an idea of what it would sound like in my listening room...
Old 21st June 2017, 11:54 PM   #2028
Got Foam?
xrk971's Avatar
Jim in the DNA thread built prototype out of XPS foam board.
Old 22nd June 2017, 06:59 PM   #2029
One question I have is how a horn design responds to multiple drivers? I guess it's not as easy as twice the Sd -> twice the volume or anything like that. I really like the small form factor of the DNA horn. So let's say it sound great with my W5-2143 but SPL is not enough in my (fairly large) listening room. I currently got my pair of W5-2143 assisted by a pair of subwoofers. I would love to get rid of the subwoofers and maybe a horn (or TL) could fill in the low end but I guess I would still be stuck with low volume background music. Not a big problem but it would be nice with some extra SPL...
Old 22nd June 2017, 09:58 PM   #2030
Got Foam?
xrk971's Avatar
It's not so simple with BLH's - needs to be simulated and the sims are quite accurate. A rule of thumb is to pick two drivers so that their sum Sd is about the same and sum Vas is the same, assuming Qts is the same. So sticking two W5-2143's in a DNA probably won't be ideal, but this is where the sim can help. I can adjust width of cabinet which increase Vas and allowance for larger Sd. Worst case is a cabinet that is twice as wide.
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 04:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 01:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 05:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
