Mini Karlsonator (0.53X) with Dual TC9FD's
Old 31st October 2014, 01:43 AM   #1011
EddieT is offline EddieT  United States
Thanks X, that is a bargain.
Old 31st October 2014, 02:29 AM   #1012
a3cervo is offline a3cervo  Philippines
X, thanks for this very helpful info, very favorable to my intended application. A couple questions more if you don't mind:
you've built other enclosures for the TC9FD, how would you compare the MK .53x vs the DCR & others in terms of details & lows?
Based on your findings, which is the best driver you've used for the MK 0.53x/0.4x?
Anton
Originally Posted by xrk971 View Post
0.53x has deeper bass in the 50Hz range vs 70Hz for 0.4x. Against a wall is best for deepest bass extension so no problem there - you will like the sound. The 0.53x also has advantage of higher sensitivity and more headroom as the drivers in parallel have 91dB sensitivity at 2.83v. If you have room, go with the bigger one. Good luck.
Old 31st October 2014, 03:14 AM   #1013
freddi is offline freddi  United States
freddi's Avatar
a question X - did you ever work out an 8 cubic foot external bulk Karlsonator15 to compare to K15?
Old 31st October 2014, 03:21 AM   #1014
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
The dual driver 0.53x has sound that will fill a larger space - great for a small party. The bass and imaging on the DCR is better but bit won't get as loud - really meant for smaller rooms and close range monitor application with moderate SPL's. I have not built this but my guess is that a 0.53x with dual 3FE25 (2x8ohms parallel) will have 97dB sensitivity and could be the cat's meow.
Best is always tough to say.
I haven't tried anything other than dual tc9fd myself in a 0.53x. But as I said above, dual 3FE25's may be the ticket.
For 0.4x the 3FE25 is my new favorite. Although TC9FD is a close second for slightly smoother mids.
Anton
Old 31st October 2014, 03:22 AM   #1015
Got Foam?
xrk971's Avatar
Not sure what you mean Freddi? You want an apples to apples comparison of Karlasonstor at 8cu ft? That is a big box - what driver?
Old 31st October 2014, 03:59 AM   #1016
Thanks X! Will check out 3FE25s.
Old 31st October 2014, 04:18 AM   #1017
freddi's Avatar
make the Karlsonator15 the same external bulk as K15 (~7.75 cubic feet) - use a traditional style driver on sale for $199 including the compression driver, make it taller and narrower than K15 and see if the low end can be significantly extended without losing punch.
if you can't get it in the same bulk, then raise it a bit
P AUDIO_BM15CXA
I kind of doubt if Qts is this low but "maybe"
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
WOOFER MODEL - BM15CXA
Low Frequency Specifications
Nominal Basket Diameter
15" / 381mm
Impedance
8 ohms
RMS Power Rating
350 watts
Program Power Rating 700 watts
Frequency Range
40Hz - 18kHz
Sensitivity (1W/1m)
101dB SPL
Voice Coil Diameter
2.5" / 63.5mm
Magnet Weight 100 oz.
High Frequency Specifications
Rated Impedance 8 ohms
RMS Power Rating 40 watts
Program Power Rating 80 watts
Frequency Range 1.5kHz - 18kHz
Sensitivity (1W/1m) 106dB SPL
Voice Coil Diameter 1.75" / 44.5mm
Magnet Weight 3.74 lbs.
Thiele-Small Parameters
Resonant Frequency (Fs) 39 Hz
Impedance (Re) 5.6 ohms
Mechanical Q (Qms) 6.45
Electrical Factor(Qes) .25
Total Q (Qts) .24
Comp. Equivelant Vol. (Vas)
9.09 ft3 / 257.5 Liters
Voice Coil Overhang (Xmax) 2.75 mm
Surface Area of Cone (Sd) .083 m2
BL Factor (BL) 18.45 T-M
Old 31st October 2014, 07:59 AM   #1018
freddi's Avatar
better yet - coax which I own http://bjl.audioconcept.free.fr/Arch...IES/SN-15C.pdf
fs = 41.0, Re= 5.3, Le = 0.36mH, Qms = 5.030, Qes = 0.371, Qts = 0.346, Vas = 214.54 liters, BL = 16.4, Mms = 73.3 gm, Sd = 0.0850 m2, Xmax = 3.3mm, eta zero = 3.82%, Hag = 12.0mm, Hvc = 18.5mm
got one in a vintage K15 = nice sound - good neo HF driver too
Old 5th November 2014, 05:14 PM   #1019
vitorio is offline vitorio  Spain
Just an idea that works for me filling the part above driver:
cut a piece of poliester matt same wide and twice long, fold it and push it in.
The poliester get packed very tight at the end, and less above speaker. The felt help to keep it in place, doesn't fall.
Old 5th November 2014, 06:20 PM   #1020
Got Foam?
xrk971's Avatar
Vitorio,
Nice build! Is that a 0.4x? What driver will you be using?
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 03:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 12:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
Copyright ©1999-2019 diyAudio
