A Speaker that Kicks Butt in Large Spaces
Old 18th March 2019, 12:17 PM   #1251
freddi is offline freddi  United States
freddi's Avatar
Acoustic Control's 115BK "seems" in my limited opinion to have a good front cavity shape vs depth. Even with its large port blocked, response isn't too bad.
Would the effects scale downwards to a 12 inch size? How much does its port area affect system tuning ?
there was no damping whatsoever in the 115BK cabinet below. Fb for 115BK is ~53Hz.
Here's a rare Karlson-type built by the late Ernst Beck and probably with license from Transylvania Power Company.
This particular cabinet is owned by Franz Stolz and has a 4" x 4" port vs 3.25" x 8.375" for the similar Acoustic Control 115BK.
I Imagine the BEC cabinet to share inner layout with my sketch
of Acoustic Control's 115BK
The BEC cabinet does appear to have a 3-panel reflector vs one board plus a piece of pine
for 115BK
Old 19th March 2019, 01:44 AM   #1252
freddi's Avatar
oh - when making these things - don't forget that the initial gap width may greatly affect the outcome of how they sound. When I swiveled these same "wings" together for a 5/8" top gap width, it sounded like things were having trouble getting out of the cabinet - almost like it was "konstipated" -opening this particular set of wings to 1.2" top gap opened up the mids, highs, and bass "transients". It did not make hardly any difference to the microphone on and off axis, perhaps due to the large and varied source area. K-experimenter Carl would use several sets of wings to evaluate (perhaps with math - being math challenged - I have to do it "by ear"
this was a good little cabinet and the Smith distributed source horn a good compliment (I ran it in mono with vintage recordings) - Having an 18 inch speaker and less bulk than K15, it had a somewhat higher cutoff. It was made like a "big" (1958 style) K12 for its cavity - had a real lowpass choke. I added a 20 liter stub to the top of its front chamber which lowered f3 a bit and smoother ripple - but it sounded fine without the stub.
Old 19th March 2019, 10:34 PM   #1253
moray james is offline moray james  Canada
Fred: what does the response look like? Where does it roll off at?
moray james
Old 19th March 2019, 10:53 PM   #1254
freddi's Avatar
response was pretty smooth for an 18 inch driver - probably rolled off below 70Hz outdoors - adding a 20 liter top chamber made it more like K15 - IIRC the back chamber was only 78 liter not very big for an 18" speaker. FWIW I took wither 2.5 or 3 inches off the top of the wings to "raise" them - that didn't really matter soundwise. The original top for the cabinet is sitting, inverted on top of the extra 20 liter chamber in this picture. One time I had a much larger chamber on top - that I think created a notch in the response - much like it might in a BP sim.
The cabinet on the left was an attempt at a "Fig.6." Karlson and originally ran a 15. I enlarged the opening with a jigsaw to 16 - that was my first "K18" and it could throw out a good shockwave. Without a front shelf, I think perhaps the chamber was too deep as the hole above 200Hz was greater than seen in K15. Then again , that cabinet had two vents rather than a centered vent and the center vent tends to do the most "fill".
Old 21st March 2019, 08:04 AM   #1255
jackson9 is offline jackson9
I'm planning to setup a home theater in my living room. But I'll be using a laptop which will be connected to a projector. In doing so, I followed these steps from a reliable site via google search result - How To Easily Connect Your Laptop To A Projector. Having said that, I want to know what type of speaker should to use.
Can anybody help me? Rest assured all suggestions will be highly appreciated. Thanks.
Old 21st March 2019, 12:19 PM   #1256
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Are you considering a Karlson for HT? Not sure if this is the right thread for you. You could use smaller 0.46x scaled Karlson’s with a 6in pro audio coaxial driver. That will work well down to 100Hz and get you THX sound levels. Use a subwoofer below 100Hz. The K-aperture provides a wide sweet spot.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 22nd March 2019, 09:20 PM   #1257
freddi's Avatar
@xrk971 - did you ever re-visit your little 6MDN44 K? - just wondering how that would sound for augmented by a capable tweeter compared to your other projects. Its too bad there doesn't seem to be any little 6.5CX like Diysoundgroup's Volt 6 available that's affordable.
xrk971 0.35X K15 for B&C 6NDN44
Going by the original K15 vent size, 0.35 scale vent width would be 40mm
Old 22nd March 2019, 10:23 PM   #1258
freddi's Avatar
maybe if this little Celestion 6.5cx with silk dome tweeter becomes available, that will offer a little K to be used with a small sub
TFX0615 coaxial driver
A Speaker that Kicks Butt in Large SpacesHide this!Advertise here!
Dipoles/Ripoles and small spaces? REDSKIN Subwoofers 2 30th August 2008 08:59 PM
Self-Building Battery, For Microscopic Spaces Nordic Everything Else 0 19th February 2007 09:45 AM
8" Bolt sub kicks butt MikeR Multi-Way 0 9th May 2004 10:32 AM
midrange for kicks caz Multi-Way 10 28th April 2004 05:59 PM
Copyright ©1999-2019 diyAudio
