A Speaker that Kicks Butt in Large Spaces
Thread Tools
Old 11th October 2017, 05:47 PM   #1091
freddi is offline freddi  United States
freddi's Avatar
Default "HAK"
here's one of Carl Neuser's earlier "high aspect Karlson" textboxes. Details were removable so different ports, port position, rear lowpass gap, tapers, front shelf deflector and front chamber reflector could be evaluated. Carl is a stanch proponent the curved reflectors per the final installment of Karlson's "Acoustic Transducers" patent.
With my crude HAK8 , similar in bulk to a Karlson12 and both loaded with W8-1772, the skinny, taller box had 2-5dB less output in the 110-220Hz region than Karlson's 1954 K12. What might be the reasons for that observation?
Old 11th October 2017, 07:11 PM   #1092
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Was volume the same? A larger volume box will have lower output in midbass.
XRKaudio Store // Manufacturer’s Forum
Old 11th October 2017, 08:01 PM   #1093
freddi's Avatar
yes - pretty much the same volume between the HAK8 and the old Karlsonette K12. It was like the normal aspect K12 emphasized the 110-220 hit region more.
Old 11th October 2017, 08:28 PM   #1094
Got Foam?
xrk971's Avatar
Does the HAK have deeper bass extension? It's longer path length could be making behave more like a TL vs a 6th (or 8th) order bandpass alignment.
Old 12th October 2017, 08:33 AM   #1095
freddi's Avatar
with the horizontal port right above the speaker, my HAK8 didn't seem to have a real LF advantage over the K12. I can't remember how careful I was with regards to having both cabinets in the same spot (and same with mic placement) I've not played with that cabinet since cutting a 3" hole near the top of the slant board. An initial impedance plot looked very odd with my AN8. I'll try the W8-1772 which is still limber. Nirvana's surround goop seems to dry, stiffen and raised fs by a half octave from ~41 when first got the speakers to the mid 60's. (That's another plus for FE206EN)
It might require a short duct on the 3" hole to tune things for the HAK8 (?) - where do you think I should set tuning? 60? - lower ?
Old 13th October 2017, 06:22 PM   #1096
freddi's Avatar
Default TwoGoodEars K15 blog
TWOGOODEARS - トゥーグッドイアーズ: A well-spent day: the making of a Karlson bass enclosure pair
Old 16th October 2017, 06:22 AM   #1097
freddi's Avatar
Question for xrk971. If one is to use Mark Audio's Alpair 12P in a K - Which K suits it best overall? Would it be a Karlsonator? How would it play in GregB's Karlsonator6 which has Fb ~60Hz? Would it be lost in a stock Karlsonator8? What can be done with the original K concept ? How about a well thought out XKi ?
Def_Driver "ALpair12P" | ~6.5 in. Full Range driver from Mark Audio
Sd=147.41cm2
Fs=42.15
Mms=10.217g
Qms=1.981
Qes=0.333
Re=7.000
BL=7.540T-M
Le=0.054mH
Vas=43.060L
Old 16th October 2017, 04:02 PM   #1098
Got Foam?
xrk971's Avatar
Sd=147.41cm2
Fs=42.15
Mms=10.217g
Qms=1.981
Qes=0.333
Re=7.000
BL=7.540T-M
Le=0.054mH
Vas=43.060L
Hi Freddi,
I ran this sim a long time ago - yes, a 0.67x scale Karlsonator is best for the A12P. It will get about 93dB sensitivity and F3 of about 48Hz.
X
Old 16th October 2017, 08:16 PM   #1099
freddi's Avatar
another kuestion - for a given lower Q driver and regular K as in the form of 115BK, what changes to the original scheme could help tame a peak which can occur? (see area in red oval) - does one add a resonator to the front chamber?
https://i.imgur.com/YZemfus.jpg
oddly, its not noticeable with 115BK indoors - or my KK-audio boxes with EV15B - and the bass, although high cutoff, does
not sound "hollow" when a K-tube treble is added to the little 4.3 cubic foot K-box
that peak can get out of hand sometimes - kinda weird - it doesn't sound crazy in a slit vent K12 either
loaded with old spec B102 ( that driver measures Qts ~0.23)
Old 17th October 2017, 04:18 AM   #1100
freddi's Avatar
- wonder how accurate this sim comparison is overall ? - two K cabinets - one is TB46's version of MMJ's Karlflex at 73L. The other, Acoustic Control's 115BK, both with 2035H
A Speaker that Kicks Butt in Large SpacesHide this!Advertise here!
Thread Tools
Dipoles/Ripoles and small spaces? REDSKIN Subwoofers 2 30th August 2008 08:59 PM
Self-Building Battery, For Microscopic Spaces Nordic Everything Else 0 19th February 2007 09:45 AM
8" Bolt sub kicks butt MikeR Multi-Way 0 9th May 2004 10:32 AM
midrange for kicks caz Multi-Way 10 28th April 2004 05:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
