A Speaker that Kicks Butt in Large Spaces
Thread Tools
Old 21st May 2017, 07:00 AM   #1011
freddi is offline freddi  United States
freddi's Avatar
haha - that's where we could use some FEA modeling - whats the board above the baffle look like in your little K ?
Hey X - since K's usually excel on guitars - start around 1:44 in this video to get past the talk
https://www.youtube.com/watch?v=RjjmutHRs44
Old 21st May 2017, 07:55 AM   #1012
freddi's Avatar
how does it do on the Siena Pianoforte ? (a wonderful instrument) https://www.youtube.com/watch?v=wadANaPrmjg
Old 21st May 2017, 09:16 AM   #1013
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I think it actually sounds pretty good playing back guitar. The attack and dynamic range is quite nice. From listening, I would guess it goes down to about 100Hz.
Here is a recording of the classical/flamenco guitar video you linked.
Change extension from .asc to .mp3 to listen.
Old 21st May 2017, 03:17 PM   #1014
hoyungh is offline hoyungh
Well done X. I pop off to church on sunday morning and when i come back all this interesting news is here. I should have realised something was up when you commented on the TC9FD 0.4 karlsonator.
Old 21st May 2017, 05:51 PM   #1015
freddi's Avatar
that recording of Kurvey-K3 with guitar has good dynamics and tonality - just a bit lacking on the low end
perhaps someone will try Kurvey with larger drivers
Old 21st May 2017, 10:58 PM   #1016
freddi's Avatar
hey X - are you going to present Kurvy-K as a fullrange project ?
Old 21st May 2017, 11:02 PM   #1017
Got Foam?
xrk971's Avatar
You mean give details on internal dimensions etc? There is not much to say other than it's a direct scale-down per driver nominal size and I simply reduced the front chamber volume by curving the aperture all the way to where the top board with the vent meets the top panel.
I think it will work well with a larger driver like a 12in coax.
Old 21st May 2017, 11:25 PM   #1018
freddi's Avatar
well - you might post it separately with a brief discussion - regarding 12cx version - do you think the 1956K12 style most appropriate ?
would it be kinda like so ? - the way I crudely did this, there isn't a lot of front chamber volume reducitno. I don't know what's "optimum" for some 12CX
Old 22nd May 2017, 12:51 AM   #1019
Got Foam?
xrk971's Avatar
That's basically it but mine started tangent to the vertical from the bottom front. Not a big deal and I have no basis for reducing front chamber volume other than to allow curve to work. Reducing front chamber volume loads the cone more for higher SPL actually. But having a curve on a small full range driver makes a difference.
Old 30th May 2017, 03:33 PM   #1020
Freddi about the FE206EN the manufacturer recommended a 45 lit bass reflex enclosure. the equivalent K will do 50Hz . the existing 0.6 k you have has a bass reflex vol 22.5 lit and do 70hz.
A Speaker that Kicks Butt in Large SpacesHide this!Advertise here!
Thread Tools
Dipoles/Ripoles and small spaces? REDSKIN Subwoofers 2 30th August 2008 09:59 PM
Self-Building Battery, For Microscopic Spaces Nordic Everything Else 0 19th February 2007 10:45 AM
8" Bolt sub kicks butt MikeR Multi-Way 0 9th May 2004 11:32 AM
midrange for kicks caz Multi-Way 10 28th April 2004 06:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
