A Speaker that Kicks Butt in Large Spaces
Thread Tools
Old 19th May 2017, 05:00 PM   #1001
hoyungh is offline hoyungh
Sorry Freddi for not communicating clearly. For this .205 volume K you will be looking for a full range driver with an optimum vented bass reflex volume of 22 litres. internal volumes are the deciding factor. since you already have the box maybe you can scout for a good driver. good luck and good hunting
Old 19th May 2017, 07:15 PM   #1002
freddi is offline freddi  United States
freddi's Avatar
thakns - I'll think about some of the stuff I already have - my Nirvana Super8 hav stiffedn moving Qts up to around 0.38 but fs moved to the 60's which moves fs down - gotta check. Do you have any ideas for a "new" K? A "recipe" ?
Old 20th May 2017, 01:28 AM   #1003
Freddi you are probably looking for a smaller speaker. for instance one of X's favourite the TC9FD has an optimum bass reflex volume of 15 litres.
Old 20th May 2017, 01:51 AM   #1004
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Freddi has a set of 0.40x Karlsonators with TC9FD. Much smaller than 15L I think.
Old 20th May 2017, 03:20 AM   #1005
freddi's Avatar
I'm looking for the best small K which can play 120+ dB peaks as to compete with larger front loaded horns. I don't think an 8 will do it. I would like a dedcated midrange K with good sensitivity which could handle power and not have obnoxious resonances/dips/peaks
Old 20th May 2017, 03:33 PM   #1006
Freddi out of the speakers you have which sounded best as a full range unit. Maybe we can start from there and hopefully get to where you want to be
Old 20th May 2017, 07:11 PM   #1007
freddi's Avatar
probably for a small fullrange, FE206EN (stock Fostex)
Old 21st May 2017, 06:26 AM   #1008
Got Foam?
xrk971's Avatar
Default Kurvy K with 3FE22
This is a K15 scaled down for a 3.5in Faital Pro 3FE22 (16ohm) driver. The curved front does a nice job of eliminating the front chamber hollowness. I am listening to it now (powered by Pass M2 Class A and my own SE Class A CFP preamp) on some jazz vocals with a stand up bass and have to say that I am surprised how good it sounds. I haven't measured it, and don't plan to, as these are just fun speakers. The 91dB sensitive 3FE22 has a particularly strong Nd magnet motor, so I think that works well with this alignment. The imaging is very nice and tight with a single fullrange.
Base measures 5.5in x 5.5in and whole thing is 9in high - a very compact little K. I know Freddi will love this
Old 21st May 2017, 06:38 AM   #1009
freddi's Avatar
brilliant little K - and "TWO TONE" - it would be interesting to hear how the curved aperture would fair in a larger K. I've never heard 3fe22 but do like 4fe32.
Old 21st May 2017, 06:50 AM   #1010
Got Foam?
xrk971's Avatar
Haha, another project for thejessman... he can use kerfed "bendy" ply for the aperture? Or soak plywood in water overnight the screw down while wet and it will hold its shaped after it dries.
A Speaker that Kicks Butt in Large SpacesHide this!Advertise here!
Thread Tools
Dipoles/Ripoles and small spaces? REDSKIN Subwoofers 2 30th August 2008 09:59 PM
Self-Building Battery, For Microscopic Spaces Nordic Everything Else 0 19th February 2007 10:45 AM
8" Bolt sub kicks butt MikeR Multi-Way 0 9th May 2004 11:32 AM
midrange for kicks caz Multi-Way 10 28th April 2004 06:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
