Ever think of building a Cornu Spiral horn? Now you can!
Old 29th September 2018, 07:18 AM   #2551
Doctor Why is offline Doctor Why  Germany
Doctor Why's Avatar
Especially in Full-Range Cornus it is a good Idea to leave some Space for a little damping Material ...
Even in my Bass Cornu, a Mat of BAF Cotton has had a positive impact.
D.W.
My Rig: DIY Backloaded Horns with Magnet-modified Fostex FE206en + Modified S.M.S.L. SA98 + Source Thinkpad T430 w. USB Soundcard + Synology 32TB NAS
Old 6th October 2018, 03:26 PM   #2552
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
Hey X, since I came up on a pair of Fountek FE85 recently, do you think they would be a drop-in for the 20x3 cornu with TC9FD, or do you think I should save them for a 24" or so build, or something else? I figured it's reputation for being a bit bright up top may be a decent match for how bass heavy the cornu can be.
I've got the 20 fronts/backs cut and the spirals drawn out, but haven't started on the channels yet.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 6th October 2018, 10:38 PM   #2553
ellisr63 is offline ellisr63  Mexico
How would these work as surrounds or height channels? How low do they go?
10 DIY B&O Bridged amps for biamped horns, Yamaha cxa5100 preamp, Xilica xp4080, Samsung 65" 4k fp. DIY projects... 5 horns with 3 being DIY Synergy horns for living room.theater
Old 7th October 2018, 02:49 PM   #2554
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
The FE85 is a perfect match for a 20in to 24in Cornu - about 2.5in to 3in thick should work fine. I would personally go with 24in and 2.75in. But since you have 20's all drawn out, go with that.
Good luck.
...now back to work on that sim for the Karlsonator for you...
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 7th October 2018, 02:50 PM   #2555
Lingwendil's Avatar
Originally Posted by xrk971 View Post
The FE85 is a perfect match for a 20in to 24in Cornu - about 2.5in to 3in thick should work fine. I would personally go with 24in and 2.75in. Good luck.
Thanks!
Old 8th October 2018, 01:07 AM   #2556
I do not mean any disrespect on this build by wanting them for height channels...I am building k402 synergy style horns for the front channels. I am also building some Klipsch Belle bass bins with some 18x10 horns for the surrounds. I am wanting something better than my JBL 8330As for my bvb height channels for an eventual Auro3d setup.
Does anyone know how they would do 12' up a wall?
Old 8th October 2018, 06:03 AM   #2557
Got Foam?
xrk971's Avatar
At 12 ft high, the directionality of the highs will be at an oblique angle and maybe not ideal. Against a wall, the bass is fine but I would worry that the mids and highs will not be loud enough.
Old 8th October 2018, 02:45 PM   #2558
Lingwendil's Avatar
Maybe ceiling mounted?
Old 8th October 2018, 04:29 PM   #2559
Our ceiling is a 32' high Boveda ceiling. The room is going to be a nightmare to treat too, but I will do my best. I really like the look, and potential sound for the buck too.
Old 8th October 2018, 04:30 PM   #2560
Thanks... I guess I will need to look for another design if I want to replace my JBLs.
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Cornu Spiral Copy Horn hersh Full Range 25 30th January 2018 01:32 AM
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright ©1999-2019 diyAudio
