Ever think of building a Cornu Spiral horn? Now you can!
Old 25th May 2018, 10:48 PM   #2521
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
That’s what they said about Sd when I scaled the FH3 for a 3.5in driver. A few years later, the FH3 lite came out for 3.5in drivers and guess what, it was the same size as the one I scaled based on Sd. It’s a good place to start and can always be optimized by modeling. But sometimes it works quite well.
Homage to FH3 scaled by Sd:
FH3-inspired Foam Core Mini Build
FH3 Lite:
Frugel-Horn Lite for 3" drivers
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 26th May 2018, 03:14 PM   #2522
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
Hey X, how do you think that those PA130-ish MCM 5" drivers we grabbed from Newark would work in a cornu? I was thinking that a 24x3 might be a good starting point...
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 26th May 2018, 09:20 PM   #2523
Got Foam?
xrk971's Avatar
Probably work well. They are 5.25in drivers so maybe 32in actually would be needed to work. Nominal is 4in and 28in.
Old 26th May 2018, 10:31 PM   #2524
Lingwendil's Avatar
Hmmmm. Do you think you could do a sim? I'm trying to figure if I want to do a pair in either a cornu or a Karlsonator first. I really want to do a cornu, and already have a pair of Karlsonator anyway, so if I end up running a separate HF driver I would rather do it for the cornu.
Old 27th May 2018, 02:40 AM   #2525
Got Foam?
xrk971's Avatar
I think the smallest Cornu that can take the MCM 55-1595 is a 30in edge. However, this driver has such a high Qts, it seems to produce quite a bass overshoot peak. But it might sound pretty fun given how much coloration there is.
This is a 30in x 4in deep Cornu:
Ever think of building a Cornu Spiral horn? Now you can!-cornu-mcm-55-1595-png
Old 27th May 2018, 09:17 AM   #2526
malthe is offline malthe  Denmark
This is the 5F/8422T01 simulated in a 35.5 cm x 4 cm cornu. Why is the whole thing dropping 12dB after the ~ 900Hz ?
Old 27th May 2018, 12:25 PM   #2527
Doctor Why is offline Doctor Why  Germany
Doctor Why's Avatar
Due to Qes= 0.69 may be a little weak for higher Frequencies in a Horn ?
My Rig: DIY Backloaded Horns with Magnet-modified Fostex FE206en + Modified S.M.S.L. SA98 + Source Thinkpad T430 w. USB Soundcard + Synology 32TB NAS
Old 27th May 2018, 03:41 PM   #2528
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Sims don’t tell you much when you ar eabove th emass corner… i.e. 900 Hz is way above where the sim is accurate.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th August 2018, 08:08 AM   #2529
haraldkasper is offline haraldkasper  Sweden
haraldkasper's Avatar
Default Question
i havent time to go throug all the pages anybody knowing what pages thew plans are
Old 23rd September 2018, 04:42 AM   #2530
Karl71 is offline Karl71  United States
Location: Northern Illinois, 50 miles outside of Chicago
Default Lowther DX55 in a Cornu?
How well would it work?
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Cornu Spiral Copy Horn hersh Full Range 25 30th January 2018 01:32 AM
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright ©1999-2019 diyAudio
