Ever think of building a Cornu Spiral horn? Now you can!
Old 12th February 2018, 12:14 AM   #2451
bonjonno is offline bonjonno  United States
Those look phenomenol Cal. Where do you plan to mount them? I've only picked up the last few pages, what is the driver u are using and is it contained in the box or is there a bump?
I built a pair of 16" Cornus last year with 2.5" Dayton drivers for my TV; every time I turn them on it makes me smile they're so bassy.
Old 12th February 2018, 12:28 AM   #2452
scott68 is offline scott68  United States
Yeah, that is what I was worried about - Since I haven't seen anything like this, I was questioning my "tangent" idea. However, I thought there might be some reasoning in this idea since the Cornu has two different lengths starting with two small channels expanding into a horns (small to large channel.) So why would it not work in reverse with two large starting channels going to tapered small channels, ie, T-Line.
Unless someone gives me some encouragement that it might work and help with the starting info that I outlined above, I will continue with my portable DOT video project. I just finished my 7 speaker, computerized DOT video artwork wall system. I like to have two projects going at the same time or I get bored.
thanks
Old 12th February 2018, 12:30 AM   #2453
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by phivates View Post
Cal doesn't do anything one could call "absolutely nuts."
You're right Fred, it's a 'controlled nutiness'
My wife has other words for it but I can't use those here on this family oriented site.
Old 12th February 2018, 12:37 AM   #2454
phivates is offline phivates  United States
Ahhhh...."You're right Fred..." my wife doesn't say that all that often...thank you Cal!
Old 12th February 2018, 12:41 AM   #2455
Speakerholic
Cal Weldon's Avatar
Thank you.
In the storage area with all the rest. No kidding, as a speakerholic, this just feeds an addiction.
TB W6-1139 woofer. Tang Band W6-1139SI 6-1/2" Subwoofer
These will give me the giggles too. I just hope they don't give me the ****s part. Every time I step up in size, they continue to amaze. I am expecting no less this time.
Here's the 20's, 27's, and 36's along with a drunken concoction I call the Penthorns
Old 12th February 2018, 12:49 AM   #2456
Speakerholic
Cal Weldon's Avatar
Well, this is a Cornu thread. To reverse it makes it a whole new speaker. Nautilus comes to mind.
I encourage you to do it. I also encourage you to start a new thread so we can see the progress as we do here in the Cornu thread. Working with foam core is fun. Seriously. I don't mind the accidental blisters at all. Yes, it happens, don't kid yourself.
Old 12th February 2018, 01:01 AM   #2457
Speakerholic
Cal Weldon's Avatar
Ahhhh...."You're right (Cal)
Happens mostly when my wallet does the talkin'
See above. I don't think we're alone here Fred.
Old 12th February 2018, 03:23 PM   #2458
Thanks for addressing all my questions Cal. And for the pics. Mmmm. Pictures. I get the speakerholic bug from time to time. Luckily don't have it at present. Too cold to think or feel anything this winter :0 In fact I've had the parts for dual TC9 0.53X Karlsonators sitting here for months. Finally a coupla weeks ago I cut out all the foamcore pieces. Now at least they're in a neat stack. But of course I have a few glorious foamy boxes to listen to already, so no rush. When the fever hits again I may take on a 27 or 36 Cornu. I can imagine that the sound out of those things is somewhat beefy. Thanks for the inspiration.
Old 12th February 2018, 05:52 PM   #2459
Speakerholic
Cal Weldon's Avatar
I wish strokes of genius would interrupt my thought process more often. While I'm lying in bed this morning, trying not to disturb the Mrs., it hit me. If you want to lay 46 ft. of glue on the edge of the foam before it skins over, you either need four people with a bottle of glue or you do something like this. It's just a paperclip taped to the nozzle. Hockey tape of course.
Old 12th February 2018, 07:07 PM   #2460
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Nice one, Cal. The super duper (patent pending) guided glue nozzle!
You could have a bottle of fine spritz water spray to keep glue moist while laying the bead down. Or use PL Premium (slow setting water activated) and spritz water on it before putting the top panel on.
XRKaudio https://www.etsy.com/shop/XRKAudio
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Cornu Spiral Copy Horn hersh Full Range 25 30th January 2018 01:32 AM
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright ©1999-2019 diyAudio
