Ever think of building a Cornu Spiral horn? Now you can!
Old 11th April 2014, 04:34 PM   #1561
edodo is offline edodo  France
Yup it's undersized, as I could have the board fairly cheap. Going bigger meant lots of wasted woods. I wanted to try out for my Cornu with a smaller model and easy to source 60cm boards...
The front box driver is a good idea! I'll give that a thought on my next cornu!
I think the channel left before bifurcation is 12 cm to 10 cm. Thanks for the sim, X!!!
Giorgio Armani met une race, ā Charles tout nu sur la plage.
Old 11th April 2014, 04:41 PM   #1562
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by gtoro View Post
Ok these are the parameters, using foam 5mm for front and back and 0,3mm for horn with this kind of luodspeaker is correct a dimension of 50cmX50cm how deep had to be the internal foam? thanks for any suggest and information
I would go for a 27.5 in x 27.5 in x 4.0 in depth. The 50 cm is too small I don't think the magnet and basket will fit.
Old 11th April 2014, 07:25 PM   #1563
gtoro is offline gtoro
Many thanks and sorry for my bad english... I will try it
Old 11th April 2014, 08:49 PM   #1564
Got Foam?
xrk971's Avatar
Edodo,
The sims of the Lcao F6 in a 24 in Cornu are not good. I am afraid you will most likely be disappointed with the performance as there is no bass below 100 Hz - sorry to bring bad news...
Here is the sim in a 24 x 4 deep Cornu with all channels intact:
Here is with only 5 cm of the initial channels remaining in a 24 in x 4 in Cornu - not very pretty looking:
If you went up to a 36 in x 4 in size it looks better but I am not convinced the driver cutout will fit and also the bass performance looks like it is still needing more volume:
I think the ideal size for the F6 is a huge 40 in x 4 in deep Cornu - but you will get bass extension down to 35 Hz (-10 dB):
Here is the cone displacement for the 40 inch:
Here is the impedance for the 40 in:
If you do build the 40 inch version - it will indeed sound very impressive with the 95 dB bass efficiency. That us very loud at 1 watt and will bother neighbors and vibrate walls and windows badly at 5 watts (don't exceed this to stay below xmax).
I don't think anyone will ever do this but if size were no object, you could even make it 48 in x 6 in deep - a whopping 16 square feet of baffle. A standard 4x8 ft sheet of plywood will suffice for one speaker's front and back, albeit only 1/4 in thick can work... Here is what you get - a solid bass extension down to 33 Hz (-3dB):
File Type: png Cornu6a-24x4-shortened-Lcaof6-freq-1m.png (37.1 KB, 465 views)
Old 13th April 2014, 08:28 AM   #1565
I guess I will do a bass reflex then. The 24" cornu I will source a cheapo 3,5"
By the way, I really like the way the LCAO sounds. Very extended and smooth medium...
Old 15th April 2014, 03:57 PM   #1566
Coen is offline Coen  Netherlands
Well i finally got around to starting a new pair of cornu's I'm going with 61cm/24inch mdf 5mm thick, a foam core of 8cm deep and ordered a pair of fostex fe103en drivers.
Old 15th April 2014, 04:00 PM   #1567
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Is 8 cm deep what X recommended?
Old 15th April 2014, 04:15 PM   #1568
Got Foam?
xrk971's Avatar
I don't think I have ever run a sim of an FE103en in a 24 inch. You may have clearance issues with the basket and the driver chamber on a 24 inch. I know Prezden had issues with the Tang Band W4 bamboo on a 24 incher. Consider a 27.5 inch cornu. Probably 27.5 x 4.5 inch should work - similar to FF125WK.
Old 15th April 2014, 05:06 PM   #1569
Didnīt want to bother him with yet another sim, i guess he would recommend 4inch - 10cm with 24 inch. But 8 cm will be close enough for me
The w4-1320sif was my preferred driver, but i had problems getting it here for a reasonable price / in a decent ammount of time. The basket should be fine, the mounting hole on the drawing of the 70cm cornu is 10cm and the driver chamber is 12cm. Scaled to a 61cm cornu that would be a 8,7cm hole with a 10,5cm chamber. The hole diameter for the fe103en is 9,2cm, so it should fit the chamber easily. I also know the xmax of the fe103en is limited (0,6mm), but i read multiple posts of people saying they didnīt run into any problems exceeding it. I also read a review of a cornu with a fostex fe103sigma (0,35mm xmax), which was very positive. Anyhow, this gives me a chance to try something new. And in the worst case i'll end up with a set of fe103en-s for another project, which isn't that bad.
Old 15th April 2014, 06:24 PM   #1570
Found Prezdens post, he made a 22inch cornu. (with a 24inch front) That would mean a 9,4cm chamber and the tang band w4 diameter is 9,5cm. So i can imagine he had problems fitting it, but i think the fostex will fit.
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Cornu Spiral Copy Horn hersh Full Range 25 30th January 2018 01:32 AM
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright ©1999-2019 diyAudio
