Foam Core Board Speaker Enclosures?
Old 2nd June 2019, 09:30 PM   #3101
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
You sandwiched the drivers between the cardboard and the foam and then glued it up? To replace the drivers you have to ruin your handywork?
Old 2nd June 2019, 11:40 PM   #3102
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I screwed the driver to the foam and cardboard as a sandwich with the cardboard acting as the “nut” for the screws. The glue was to seal the edges so that they are air tight and don’t vibrate. Yes, to remove would require destroying at least the rear cardboard mounting ring, which is replaceable. The drivers are connected using soldered wires to removeable Arduino style PCB pins and header sockets. So speaker cable is detachable.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 3rd June 2019, 01:08 AM   #3103
zman01 is offline zman01  Bangladesh
Double layer baffle...
Old 3rd June 2019, 02:20 AM   #3104
Speakerholic
Cal Weldon's Avatar
Ok so what we see is what we get. Thanks X.
Old 3rd June 2019, 02:23 AM   #3105
Got Foam?
xrk971's Avatar
I am doing a bit more listening with the Flower OB using just the Amazon "Echo Input" and it sounds amazingly full and rich. You just would not believe the sound from these cheap looking flimsy little flower baffles. The sub really makes it come alive and sound bigger than it is. I would say that this little project is right up there with sound quality rivaling that of the Karlsonator, almost. I think anyone can go out and get a cube shape 8in or 10in subwoofer and achieve the same thing I am doing with the XKi sub. A basic 2.1 amp from eBay/Aliexpress for a handful of dollars will get you setup nicely.
Old 11th July 2019, 03:03 PM   #3106
Got Foam?
xrk971's Avatar
Originally Posted by xrk971 View Post
Hi Folks,
Itís been a long time since I made a foam core speaker. Had a few hours to make one today and they turned out rather nice sounding. Super easy. Following the idea by Mattes in Jeshiís thread on EVA speakers. Itís a flower petal shaped open baffle. The flower shape reduces edge diffraction effects. Itís about a 12in diameter 5 petal flower with a support base. Using the FR58EX drivers which have an excellent flat response. Paired with a TPA3116 2.1 amp driving my own XKi sub fitted with dual 5.25in Tang Band sub drivers.
The spatial imaging is great and vocals are nice and clear. There is good top end reach on these too like an aluminum dome tweeter.
Almost any 2.5in to 3.5in full range driver can work here. TC9FD, PS95-8, 3FF25, etc.
Plans for the XKi dual driver sub are here:
XKi - X's ab initio Karlson 6th Order Bandpass
Excellent sounding sub, btw.
Old 11th July 2019, 09:19 PM   #3107
Got Foam?
xrk971's Avatar
The world’s best paper models of Ferrari F1 cars. Amazing what can be done with paper, scissors, glue, plaster and paint.
YouTube
Amazing talent here.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright ©1999-2019 diyAudio
