Foam Core Board Speaker Enclosures?
Old 18th March 2019, 05:52 PM   #3051
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Ok, I get it - an integrated BT/radio/amplifier.
You can also get a very nice sounding BT module with SD card, push buttons, and remote control for about $10. Look for Sanwu BT module with remote. Then connect that to any small Class D amp board and this will let you drive higher power speakers. They also make one with integrated Class D TPA3116 amp for about same price, but it lacks remote and SD card reader.
I have tested this and it sounds almost as good as a hard wire RCA cable. Very quiet with a cellpone 5v wall USB charger as power source.
https://www.ebay.com/i/264065004073
Here is an amp and BT 4.0 module all in one:
US TDA7492P 50W+50W Wireless Bluetooth4.0 Audio Receiver Digital Amplifier Board | eBay
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th March 2019, 07:54 PM   #3052
Yatsushiro is offline Yatsushiro  France
Here's one with TF and USB:
https://www.amazon.com/WINGONEER-Blu...1147Z7CT7X4DVT
Also available on Bangood for less than 7 shipped!
Old 18th March 2019, 08:22 PM   #3053
Got Foam?
xrk971's Avatar
I must have FM radio on my card too but did not know it. It looks the same from standpoint of BT chip. Description says needs an external antenna soldered to pad for FM.
That’s a nice one to have an amp built into it.
Old 19th March 2019, 06:29 AM   #3054
futuristic is offline futuristic
Tnx guys I already have a few if this BT amplifiers at home, but none with FM.
I will look into suggested links...
Great feature would be integrated Li-Ion charger sou you really have all in one portable solution.
Old 19th March 2019, 01:03 PM   #3055
Got Foam?
xrk971's Avatar
Just add $12 3.7v 10000mAhr LiPo pack, $1 USB charger module, and $1 DC-DC step up module. All available on eBay/Aliexpress
Old 30th March 2019, 08:55 AM   #3056
JohnnoG is offline JohnnoG  United Kingdom
There is a unique Foam Based Material that can be used in Audio,
it is a product not discussed in any great measure to date by the HiFi world,
it has great potential for a vast range of projects, I am sure it will appeal to
the creativity of some.
It is available under two Brand Names, ' Phonotherm' and 'Purenit'.
The Link is to a Data Sheet for the material.
I have two boards in a suitable size to build a Passive OB Speaker.
This will be my next project.
Downloads
Old 18th April 2019, 11:21 AM   #3057
midrange is offline midrange  United Kingdom
I have used 10mm foam board from an art supplies store. I am really pleased with the result, but found cutting it did not give really sharp edges. This meant rather a lot of glue for the small voids in the foam along the edges.
As I said I was using the 10mm board, and cutting with what in the uk we call a Stanley knife. Does anyone have any useful tips?
Old 18th April 2019, 12:02 PM   #3058
Try to find this blade locally. It is extremely sharp and it cuts foamboard like butter.
Old 18th April 2019, 01:25 PM   #3059
perceval is offline perceval  Taiwan
perceval's Avatar
Or this kind of knife. It's quite sharp and easy to exchange the blades
Old 18th April 2019, 03:56 PM   #3060
Bare is offline Bare  Canada
Cheap 1$ store blades ..the big snap off types.
Foam Core eats up blades Very quickly.
Lots of on hand blades is far more useful than pricey 'quality' blades
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright ©1999-2019 diyAudio
