Foam Core Board Speaker Enclosures?
Old 20th August 2015, 05:13 AM   #2651
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by SyncTronX View Post
X, Nope, but will have to search for it Sd and full TS params.
So what would the cusp look like? Like sharp angle?
and how to make that from the base level drawing?
I'll let you know when I get the info,
Thank you.
It looks like a sharp tall pick. Just make the two sides come together a little faster so it doesn't leave a parallel slot.
Old 8th September 2015, 08:48 PM   #2652
Got Foam?
xrk971's Avatar
New foam core TL using FF105WK here:
FF105WK TL for Desktop/Bookshelf
Old 8th September 2015, 09:43 PM   #2653
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
My goodness X, I would have thought your line of work kept you busy enough that you wouldn't have time for all this. Speaker #438 is it?
How do you like the driver overall?
Old 8th September 2015, 09:53 PM   #2654
Got Foam?
xrk971's Avatar
Hi Cal,
I am quite busy with work and other things. I don't sleep much.
Close, speaker #427
I like how dynamic the FF105WK is - good bass extension and very snappy. The peak at 7.5k still needs to be dealt with. There is also a dip near 2.1k but that is less bothersome. It's a good start and I am glad I made a tapered TL kind of like the kind PMC uses for their monitors.
Old 9th September 2015, 12:39 AM   #2655
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Nice build x!
Old 9th September 2015, 06:53 AM   #2656
Got Foam?
xrk971's Avatar
Originally Posted by BP1Fanatic View Post
Nice build x!
Hi BP1Fan,
Thanks! Did you see the video of the snappy bass? Change extension to .mov to watch in Quicktime.
http://www.diyaudio.com/forums/attac...-movie.mov.asc
Old 9th September 2015, 05:58 PM   #2657
BP1Fanatic's Avatar
My phone says the video is unsupported or corrupted.
Old 9th September 2015, 06:01 PM   #2658
Got Foam?
xrk971's Avatar
Can't do it from phone as it needs to be renamed to have .mov extension. The .asc extension was tacked on to get past the 760kB max file limit. Have to do from desktop.
Old 9th September 2015, 06:06 PM   #2659
BP1Fanatic's Avatar
Ok.
Old 27th September 2015, 04:13 AM   #2660
maggiesnmacs is offline maggiesnmacs  United States
I think tomorrow I'm going to build some mock up boxes for my infinity 120.3 dvc 12 inch subs with 13mm of xmax so I'm interested to see how the foam core would handle the excursion. I'm planning on making a 1.5 cu ft box sealed with some internal foam bracing. I'll definitely post some pics as I build them tomorrow. No matter what ends up happening it'll be better than having them just playing just sitting on the ground with no baffle haha. Even still I get decent bass down to 40hz with no box or baffle lol.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
