Help choosing an FR to use with an 8" MLTL
Old 31st January 2012, 10:04 PM   #11
chrisb is online now chrisb
Originally Posted by GaloDourado View Post
Hi Dave,
can you give an idea to my last question "what do you imagine the results will be, going from a 2-way XOed at 1.65kz to a FAST XOed at 300kz? Will it be a step up?"
Originally Posted by planet10 View Post
The FF85wk does highs as good as some much more expensive tweeters, has better mids than the 8", and with the XO moved low is both out of the critical range and driver separation at the XO is less than the wavelengths at the XO. Get them close enuff and the drivers are essentially co-incident
dave
translated from Davespeak - "yes, probably a step up"
Fate - something that people make up to try to explain how things worked out
Old 31st January 2012, 10:08 PM   #12
GaloDourado is offline GaloDourado  Spain
It seems a win or win situation. Nice!
Just one more thing: Will it be needed a cap to protect the FR85wk from some unwanted turn on/off pop noise seeing its very low xmax?
Old 31st January 2012, 10:09 PM   #13
Tks!
Old 31st January 2012, 10:20 PM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We didn't use any but one could protect (XO in the MTM is passive, in Tysen it was PLLXO), it would need to be large & i wouldn't use anything but poly, it will degrade the sonics.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st January 2012, 10:59 PM   #15
Something like this would be ok?
http://www.madisoundspeakerstore.com...fast-cap-400v/
Old 8th April 2012, 12:29 AM   #16
deanxxx is offline deanxxx  United Kingdom
FF85wk. I love this driver. I have directly compared it to the other 3.
Hi Dave, sorry to digress slightly but would you choose the FF85wk over the FE83En in an open baffle system on top of a woofer box?
thanx,
Old 8th April 2012, 01:38 AM   #17
frugal-phile(tm)
planet10's Avatar
Yes, no question
dave
Old 8th April 2012, 02:16 AM   #18
fakeout is offline fakeout  Canada
fakeout's Avatar
thanx,
I'm not qualified to answer this question but I do believe I read the FE83 does not work well in a bass reflex. I'm assuming this means maybe it's better in an open baffle.
Old 8th April 2012, 02:26 AM   #19
frugal-phile(tm)
planet10's Avatar
When you are using a FR as a mid-tweeter in an OB it makes little difference how you wouldoptimally load it in an attempt to maximize the bass.
dave
Old 8th April 2012, 08:41 AM   #20
Updates:
FF85wk are at home and have already been tested in cardboard baffles. Even not in the best conditions, I have tested them crossed from 300 to 650, from 6db to 48db, underlaped to overlaped... and did not find the magic, sound was very thin.
Something very extrange that I was not able to investigate because wife asked to remove "those ugly things on top of the speakers" after 3-4 days. Things were acceptable with female voices, but male voices seemed to come from a totally diferent speaker at a diferent timing (if this makes sense).
Drivers were not broken-in when tested, so I will do tests again in future -when job let me more free time-. Now listening again with usual configuration RS225+SB29 crossed at 1440 @ 48db and sounds much better, much bodied and less fatiguing.
Help choosing an FR to use with an 8" MLTLHide this!Advertise here!
Need help with choosing port size for Usher 8948A MLTL (folded) sardonx Multi-Way 16 16th July 2011 08:56 PM
MLTL for "Hemptone" FR8? Pretty Please. G Full Range 49 12th April 2007 01:51 AM
4"x8" Port = two 4"x4" Ports for MLTL??? More Complex??? OTMOPO3OK Full Range 2 17th January 2005 04:58 PM
Copyright ©1999-2019 diyAudio
