open baffle project
open baffle project
Old 16th August 2018, 09:05 PM   #61
sqrivi is offline sqrivi  United States
With the dimensions of the room I decided to add a good amount of absorbing panels. I went about this in a bit of a different way. I decided to cut out the drywall and go into the wall so I wouldn't have 4" thick panels hanging on the wall.
Added conduit for the speaker wire.
Old 16th August 2018, 09:13 PM   #62
I filled the stud bays with denim sound insulation.
I also added brackets for a floating shelf that the gear will sit on.
Old 16th August 2018, 09:19 PM   #63
The next step was to stretch fabric over the panels.
Old 16th August 2018, 09:24 PM   #64
More work on the shelf. Installing outlets to keep wiring tidy.
Old 16th August 2018, 09:29 PM   #65
Trimmed the panels with some simple molding.
Old 16th August 2018, 09:37 PM   #66
The gear that I will be using is Pro-Ject. They are more known for their turntables but the audio gear is fantastic.....plus I really like the simple clean look. I will be using the Pre Box DS2 analog, CD Box DS and Amp Box DS2.
Old 16th August 2018, 09:59 PM   #67
Finished trim paint and the room is complete. Clean and simple look. Really pleased with the results. The speakers are rock solid...the imaging is crazy precise...speakers perform much better with the room treatment.
Wiring is nice and tidy. No visible wires from the listening position.
Old 17th August 2018, 07:44 AM   #68
orangeart is offline orangeart  United Kingdom
We never really got many finished photos when you were building these, can we get some nice shots all-round of the speakers please?
Surely building speakers could be easier...
www.kjfaudio.co.uk
Old 17th August 2018, 07:09 PM   #69
I will get some pics of the speakers when I get off work. While the paint work was fantastic, the fit was terrible. I told the guy not to mess with the edges of the inserts because I had them fitting perfectly. Turns out someone else did the work and the guy I talked to didn't fill him in. I got the inserts several days after everything that was painted black and then took a couple of weeks to get some time off to do the assembly. It wasn't till then that I found out that nothing fit right. I went back to the place to see what could be done and they were out of business......lesson learned I guess. I should have checked through every step of the paint process.
Old 18th August 2018, 12:19 AM   #70
Bummer, I'm sure they are still way past what most of us manage though.
www.kjfaudio.co.uk
open baffle projectHide this!Advertise here!
New project- open baffle recommandations? PreSapian Multi-Way 33 16th March 2010 04:53 PM
Need help for my first Open Baffle project anilva Multi-Way 8 22nd January 2010 01:00 AM
First open baffle project Moondog55 Multi-Way 18 10th August 2008 05:35 AM
open baffle project mastarecoil Full Range 25 29th November 2007 06:08 AM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 10:11 AM
Copyright ©1999-2019 diyAudio
