would fe206esr work in fe208e sigma enclosure
Old 21st August 2019, 02:29 PM   #41
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Originally Posted by FreedomJazzDance View Post
By the way, appreciate if you can clarify the differences between this 3 types of attenuators from Fostex:
https://www.fostexinternational.com/...ts/pdf/att.pdf
For what I understood, R80B and R82B are the same, the difference is that R80B can handle more power.
More or less. Fostex do not always provide a great deal of information about their products.
What about the R100T? It can attenuate less dBs, but more precisely? and have a transformer inside will provide a better sound quality?
It's the nominally high-end attenuator. Some prefer transformers to resistors; technically it should be a superior adjustable solution but whether that translates into superior real world performance is open to question. Given the significant extra cost and the fact that it's only operating on a supertweeter (where human hearing acuity isn't particularly good) I wouldn't bother myself.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 21st August 2019, 02:38 PM   #42
FreedomJazzDance is offline FreedomJazzDance  Brazil
FreedomJazzDance's Avatar
Thanks sir.
Old 21st August 2019, 08:37 PM   #43
GM is offline GM  United States
GM's Avatar
FWIW, etc., IME such subtle improvements are lost on all but folks with either perfect pitch and/or at least have lived a life in low ambient noise areas. Had a relative that grew up in rural South Ga. visit me in the late '60s [Atlanta fringe near a freeway, malls, etc.] and his hearing was so keen he had to wear my wife's winter earmuffs after our Cocker Spaniel's toenails clicking on the kitchen's slate floor, quote: "drove ten penny nails through his head".
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st August 2019, 09:06 PM   #44
Scottmoose's Avatar
Blimey. Now that's definitely going to fall into the 'acute' category. I'm guessing he hadn't spent much time near Magnum V8s then?
Old 21st August 2019, 10:09 PM   #45
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
Requirement for sub(s) would be very much dependent on room size/speaker location and program material. Vital? - maybe not, but I've yet to heard a single driver/FR system that didn't benefit from highpass filtering - whether passive line level or "active" - and separately powered bass support.
Something like the basszilla is a proven design w FE208e∑ that adds woofers and tweeters.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st August 2019, 10:24 PM   #46
frugal-phile(tm)
planet10's Avatar
... is better crossover without the Lpad solution? and just try the Lpad
A single R in series works, but the filter would need adjustment for each R change. The other solution is 2 Rs in series with one end of the Tweeter. This is just an L-Pad with fixed Rs — one of the ways to figure out what size Rs, is to use a variable L-Pad and when right, measure the Rs on each leg.
And too confuse you even more let me throw this out… a thot experiment i do not know if anyone has tried yet.
would fe206esr work in fe208e sigma enclosure-fe207-ft17-xo-top-gif
The topology applies to the drivers you plan to use.
dave
would fe206esr work in fe208e sigma enclosureHide this!Advertise here!
Attenuation circuit findings Fe208e sigma adamt Full Range 0 22nd June 2010 02:20 AM
Metronome FE208e Sigma theskintman Full Range 3 2nd March 2010 06:21 AM
contour/notch filter for Fe208e sigma? adamt Full Range 1 16th April 2009 02:15 PM
FE208E Sigma as midrange driver LageB Multi-Way 3 8th January 2004 09:51 AM
Copyright ©1999-2019 diyAudio
