Frugel-Horn Mk3 Builds & Build Questions
Thread Tools
Old 14th January 2021, 06:55 AM   #1541
nandappe is offline nandappe  Japan
My choice , final adjustments.
Minimal sound absorbers.
Dump-duct Area:91cm2(6.5x14cm) , Length:10cm
My FH mk3 is thunder and storm sounds.
7HD+Frugel Horn - Final adjustment version [ My Final Choice ]---------Damp-Duct (S:91cm2 , L:10cm) - YouTube
Old 14th January 2021, 11:28 AM   #1542
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Originally Posted by alsyd View Post
This is really interesting! Can someone please explain the thinking behind a ‘Damp duct’?
He's changed the internal low-pass choke into a duct to lower tuning. While it does achieve that, it also entails some compromises that haven't been mentioned and are somewhat at odds with the design goals, so it's not something I would recommend to others (while acknowledging that it suits nandappe).
The 2KHz aspect is either another minor difference from measurement setup (no criticism implied -you can get such changes through something as simple as different atmospheric conditions), or possibly from adjusting the damping & killing an internal reflection: the enclosure does not operate that high in terms of producing output, and FH3's damping scheme is designed to be user-adjustable.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
  Reply to this post
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Thread Tools
Frugel-Horn Mk3 planet10 Full Range 1825 27th October 2020 10:35 AM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 562 27th October 2019 07:25 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 08:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 02:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 01:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
