Frugel-Horn Mk3
Frugel-Horn Mk3
Thread Tools
Old 26th October 2020, 08:30 PM   #1821
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
Originally Posted by daicymraeg View Post
I understand the Pensil 11 and Horn XL use 6.5” drivers and the Horn Mk3 uses a 4” driver.
P11 is a 6” driver. FHXL was designed with specific attention to the 5.25” A10x.
FH3 typically has a 4” - 4.5” driver. but we have squeezed a 5.25” in. Probably better in FHXL.
FHXL and Pensil are both good, designed by Scott. The FHXL has greater bass gain, goes marginally lower, and is a more interesting shape. Pensil has a more compact footprint.
If you are working with one of Stefan’s flat-paks, the difference in assembly complexity is minimal. The FHXL does have fewer bits to it (largely due to the frame needed at the back to screw the back on).
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 26th October 2020, 08:34 PM   #1822
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
As had been mentioned, the FH3 probably doesn’t move enuff air to satisfy many of the genres you listen too.
If you need bonkers levels, and bass, you can add the (mostly undrawn at this point) the deflector/stealth woofer to the build.
This is exactly the 2-way approach i would take, and you only need to do step 2 if step 1 (FHXL or Pensil) satisfies your needs.
What kind of amplifer do you have?
dave
Old 26th October 2020, 10:31 PM   #1823
daicymraeg is offline daicymraeg  Belgium
Thanks for everyones replies. Its very helpful.
I’m not too concerned about having a lot of bass because I have neighbours which I don’t want to disturb too much. Investing in a sub to use during appropriate times in the day will suit me more and can be an option further down the line.
In terms of amps I have a Cambridge Audio Azur integrated which outputs 50w per channel. This is about 15 years old. However this is the start of building a new system and I understand its best to start with the speakers first and then find an amp to match the speaker. I don’t crank my amp too high…..I’d guess about 65 to 70db listening levels.
I’m drawn to the Frugel kits because of the cabinet quality being 18mm birch ply, the cnc machining and ease of construction for a non-woodworker like me. And the quality full range driver means the absence of a crossover. Off the shelf speakers seem to offer much less than this by the time everyone in the supply chain has taken their cut.
I think I’m leaning towards the Pensil 11 because of the smaller footprint.
Old 27th October 2020, 01:08 AM   #1824
chrisb is offline chrisb  Canada
The Cambridge amp might be more than sufficient in terms of power and sonic quality, and unless it lacks features that you want/need in your “new” system immediately, it’d be the last component I’d think about updating. For me source(s) and upstream signal processing would be higher on that priority list - but of course that’s a whole ‘nother can of worms.
Not surprisingly to anyone familiar with my backstory, I’m a fan of the FH family, but have found the Pensils to be more practical for my particular domestic situation. My current multichannel system has incorporated A10.3s going on 3 years now, and I’m quite happy with them - no doubt the 11s would deliver at least as well.
It’s been a slice kids
Old 27th October 2020, 01:16 AM   #1825
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
...Cambridge Audio Azur integrated which outputs 50w per channel. This is about 15 years old...
Certainly sufficient power. I usually recommend min 10w. Given you ar eplanning on upgrading ikely not cost effective unless you diy. I haven’t heard one but they have good cred.
As Chris suggests next up would likely be source. But everything makes a difference.
dave
Old 27th October 2020, 09:35 AM   #1826
jemraid is offline jemraid  United Kingdom
Frugel-Horn Mk3
I listen to the (new) Tangerine Dream with my FH3s and CHP70s a wall of sound from 40Hz upwards at concert volume. Really Great!!
Cheers
[edit] 10 Watts Hmmmmmm!!! With the amp at waking the dead volume and a full range wall of electronic music. I connected an ammeter in series with the +V output it registered between 0.2 to 0.4 Amps. At 12v = 4.8 Watts divided by 2 = 2.4 Watts less 10% for efficiency wastage = 2.16 Watts or 1/2 that at 0.2 Amps.
Frugal Horn Mk3s Simple illustrated build, Class D XH-M590 TPA3116D2, Evaluation 3116 vs 3886: https://fh3classd.blogspot.com/
Old 12th March 2021, 12:01 AM   #1827
qingcai is offline qingcai  United States
dont know if you own the website:
Home - Planet HiFI
the CDN you using from your website does't have :
'Access-Control-Allow-Origin' header
so chrome think it's not safe and will block everything like below:
GET https://go.ezoic.net/detroitchicago/audins.js?cb=192-0 net::ERR_BLOCKED_BY_CLIENT
Old 12th March 2021, 12:35 AM   #1828
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
Loose chrome is all i can say.
The site is simple html.
dave
Old 12th March 2021, 12:47 AM   #1829
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Home - Planet HiFI
That's not Dave's website. And chrome works fine on that site.
jeff
Old 12th March 2021, 12:54 AM   #1830
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
Thanx for catching that Jeff.
dave
Frugel-Horn Mk3Hide this!Advertise here!
Thread Tools
The Frugel-Horn Project planet10 Full Range 1227 30th September 2020 02:21 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
