Frugel-Horn Mk3
Frugel-Horn Mk3
Thread Tools
Old 12th March 2020, 02:10 PM   #1801
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Short version? No. Not by itself.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 12th March 2020, 07:58 PM   #1802
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
No.
There are certainly general rules, but you have to stick the numbers on a modeler and figure out what works.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 12th March 2020, 11:23 PM   #1803
bobberner is offline bobberner  United States
For anyone building any of the current Frugel-Horns, I have precut felt available in all 3 sizes for you convenience. Send me an PM or visit my website.
Old 13th March 2020, 08:04 PM   #1804
chrisb is offline chrisb  Canada
Bob - thanks for all you’re doing to continue the availability of these great enclosure designs.
I think you need to post your URL in signature line, or are you already in the vendors’ sub-forum?
Itís been a slice kids
Old 13th March 2020, 08:16 PM   #1805
Cindra is offline Cindra  Croatia
Big Wood Studio
Found it, very nice.
Bob, can you tell what are those L shape pieces of wood for?
Old 13th March 2020, 10:42 PM   #1806
Default Hmmmm
Originally Posted by chrisb View Post
Bob - thanks for all youíre doing to continue the availability of these great enclosure designs.
I think you need to post your URL in signature line, or are you already in the vendorsí sub-forum?
Hi Chris,
Thanks for the heads up. I thought I did that already.
Old 13th March 2020, 10:51 PM   #1807
Originally Posted by Cindra View Post
Big Wood Studio
Hey Cindra,
Those are squares to help with the assembly. I figured not everyone might have appropriately sized squares on hand so I cut some out of the waste and send them along. At no extra charge of course. I may have mentioned I am making little changes in the kits as I go along to make things easier for the consumer and for me. The squares was one thing, and now I am adding marker holes on the inside of one of the "non-dado" side so that one can easily screw the "second side" on if you want to play around with the stuffing/tuning over time without having to rely on clamping the side on. This will help the WAF during the testing phase of the job. Of course, if you want to just go right to gluing the side w/o the screws for testing, no one will ever know they are there.
And thanks for the kind words!!
Bob
Old 13th March 2020, 10:58 PM   #1808
Very user friendly, I really like that approach
Old 14th March 2020, 11:07 PM   #1809
Does dado depth change some dimensions from this pdf plans? http://www.frugal-horn.com/downloads...1v0-060518.pdf
Can baffle top and sides be rounded and up to what radius without diffraction problems?
Tomislav
Old 15th March 2020, 12:29 AM   #1810
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
Yes, dados would have to be calculated into the cut. On our flat-paks the indife dado meant 5mm wider interior panel and 10mm wider external panel (not a god idea to have a 2nd interior dado on the other side).
No chafer or roundover is worst for diffraction, the bigger the better (limited to what you can fit), up to exotic suprabaffles that have the top of the FH looking like the mid cabinet off a B&W Nautilus or an Eclipse.
dave
Frugel-Horn Mk3Hide this!Advertise here!
Thread Tools
The Frugel-Horn Project planet10 Full Range 1227 30th September 2020 02:21 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
