Frugel-Horn Mk3
Frugel-Horn Mk3
Old 11th March 2019, 08:31 AM   #1741
Lohengrimas is offline Lohengrimas  Netherlands
Originally Posted by Fredrik93 View Post
What kind of amplifiers do you guys recommend as well? Right now I have a Yamaha RX-V679, not that expensive, and most definitely not super hi-fi I'm assuming.
Hi Fredrik, I got the tiny european apartment amp par excellence: the NAD d3020 (v2). It's a wonderful performer and does everything I need it to do, like play vinyl, stream from my apple devices and looks good while doing it in a small space. It has a sub out for powered subs, but I haven't used it yet (again, small Euro apartments!). A certain big audio chain from your part of the world has it on sale quite often.
Old 11th March 2019, 09:34 AM   #1742
jemraid is offline jemraid  United Kingdom
Hello Fredrick,
I've made a couple of amps for my FH3's the first was a 3876 with a large power supply, this gave me a big fat rounded sound and I listened to it for about 6 years. Lately I made a minimalist 3886 with just caps on the chip and nowhere else this is precise and analytical.
I had used a modified Philips CD723 player and thought that was very good indeeed until I bought a cheap £35.00 DVD player which is a complete joke and is in a different league to the Philips. I reckon now that my FH3's sound how they should have done when I made them in 2012. Instead of being superb they are now utterly superb.
Cheers
PS And the DVD will play anything I put into it, unlike the Philips.
Frugel Horn FH3 using very simple tools P2P Gain Clones, LM3876 & LM3886 https://frugelgain.blogspot.co.uk/
Old 11th March 2019, 11:38 AM   #1743
Fredrik93 is offline Fredrik93  Sweden
Yeah, I'm planning on keeping the subwoofer. And I am not that worried that the power would be insuffiecient with the current amp.
The only real reason I thought about getting a 2.1 is because my current one doesn't really use the subwoofer unless I enable the DSP on the amplifier. It has a "pure direct" function which just feeds the signal to the front speakers bypassing all DSP according to what I understand so far. If enabled the sound from the front speakers is very clear and sounds great, but I lose the subwoofer.
But when the DSP is enabled I feel like the sound gets tainted too much, feels like there is so much focus on the center speaker. The clarity of the new speakers are kinda lost depending if I use "NEO:6" or "PLI II". I started experimenting with settings a bit more yesterday and I think it might be okay now, but just wanted to get your take on if gettign a new amp would improve the sound drastically or not.
As for budget, I don't "really" have one. If you would have said "This amp for $800 is amazing and it will sound way better and will work for 20 years" I wouldn't have minded buying it. While I did build a pair of frugal-speakers, I'm not that frugal when it comes to technology in general
"How many and what type of program sources will be used?"
I mostly play via my Samsung TV. If it's music I use the spotify app, it's currently connected via an optical cord I believe. I will also buy a vinyl player eventually. Bluetooth is nice to have but not a must.
Originally Posted by GM View Post
Well, there's a certain synergy between tubes in general and SET in particular with 'FR' drivers and/or compression horn loading...
GM
Haha, I must say I know to little to understand what you said with transistors or what it would do for me
Old 11th March 2019, 06:22 PM   #1744
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
...I know to little to understand what you said...
Some FRs really like to be driven by a highish R output impedance. Very often these FRs are also pretty efficient so that very little power is needed. And the seamlessness of a FR mates well with an SE amp played very quietly.
This property is not unique, or even q rule with tube amps, but is a property most often seem with tube amps (SE amps most often has Rout> than that of PP amps)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th March 2019, 06:43 PM   #1745
GM is offline GM  United States
GM's Avatar
OK, it's easy enough to try this 'cheap trick' and if you like how it modifies the speaker's tone/response, then likely it would be worthwhile in buying a [kit] SET amp [5-10 W] with an output impedance = to ~ the amount of added series resistance to arrived at in testing.
Tube type is a very personal choice since we all hear the same, yet not so much, though hard to go wrong with the pioneer's choice: 300B.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th March 2019, 08:40 AM   #1746
chrisb is offline chrisb
Frederik - I think I gotcha re the DSP potentially getting in the way, and I’m coming at this with a predilection to simplify a system to as few boxes and interconnections as possible, while maintaining a pathway for future upgrading - with which the options available in integrated amps these days can easily be accomplished. As mentioned before, I’ve been quite impressed with my Onkyo surround receiver compared to the two previous Denon units, and would be inclined to recommend a look there, but no doubt other suggestions will be forthcoming.
Retired from active DIY
Old 13th March 2019, 05:40 PM   #1747
Alright, I managed to bring up the DSP "PL II" setting window on my TV at the same time I was playing music and I could adjust them as I was listening. There are two settings for PL II: "Center width" and "Dimension". Adjusted them a bit and it sounds a lot better now, a lot less focus on the center speaker. I also believe the PL II DSP is growing on me a lot, although the speakers aren't as "clear", it does sound like a "more complete" sound stage (don't know how to explain).
Some day in the future I will hopefully move into a real room and then I can invest more time in adjusting the speakers with, resistance etc, but I think I'll wait with that for now
Thanks for the tips
Old 13th March 2019, 05:57 PM   #1748
doug01n is offline doug01n  Brazil
Thanks for the tips
In my opinion, any DSP from receivers will lead to losing fidelity. If you want some serious 2.1 stereo, try to invest your money on a good stereo amp, some 100W active subwoofer with adjustable crossover and a pre amp with good Y cables. Once you set up the 2 amps, you are good to go with the volume control of the pre amp.
I have owned an Yamaha receiver and the direct stereo was always better than any of the available DSP on it.
Old 13th March 2019, 07:03 PM   #1749
Many of the latest smart TVs are capable of doing much of the source signal switching and network streaming required, as well as feeding an unprocessed digital audio or stereo analog signal out for external amps. If you donít need any more flexibility than the TV can provide, and are happy enough with the quality of its DAC, then a simple basic power amp might well be sufficient. Iím on record as to my current favorite in that category.
If you want to high pass the mains when using the sub - which I generally recommend, then a LLPXO little black box might be required at least.
Frugel-Horn Mk3Hide this!Advertise here!
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2019 diyAudio
