open backed Tapered TL? reverse-taper-into-BIB? zero-net-taper-1/2 wave resonator?
Thread Tools
Old 12th March 2010, 03:02 AM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by GM View Post
Don't forget to combine the driver/port responses, HR doesn't automatically do it as other programs do.
GM
um.....how do i combine the cone response and the horn mouth response? cant seem to figure that out......
Today I am listening to Entomed - Wolverine Blues
Old 12th March 2010, 04:19 AM   #12
GM is offline GM  United States
GM's Avatar
In the SPL RESPONSE window click on TOOLS, then COMBINED RESPONSE or use CTL + O. This will open a pop-up window that let's you dial in the path-length difference between the driver's front radiation and the vent's on the rear to the listening position. Fill it in, click OK and it will calculate/display it.
See also Pg. 15 of the HELP file.........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th March 2010, 07:29 PM   #13
GM
righty ho!
well after a bit of tinkering, i have come up with this:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
to my eyes it doesnt look great but considering its using a driver i have planned for TL at the mo, and that its only 87dB/W, the flatness and SPL gain was rather compromised. mind you i am primarily looking at this design from the stand point of a small as possible sub app, and i havent tried other drivers which may be much much better.whats the opinion of others?
Old 13th March 2010, 03:21 PM   #14
GM's Avatar
Assuming this is a 2pi space sim, then it probably has enough BSC to be damped without losing too much and the high Q peaks will be ~gone, so looks good enough to try. If 1pi or 0.5pi it will probably require a lot of stuffing to keep from sounding 'boomy'.
FWIW, here's a corner loaded example I just calc'd for an AE AV12-x. Damped and 1/3 octave smoothed, IME its response above ~100 Hz will be a fairly smooth +/- 2-3dB 'ripple' till it begins to decay away:
GM
File Type: gif AE AV12-X small Klipsch style corner horn.gif (21.2 KB, 96 views)
Old 14th March 2010, 10:18 AM   #15
peterbrorsson is offline peterbrorsson  Sweden
GM,
How big is the box with the AE?
Peter
Old 14th March 2010, 04:19 PM   #16
GM's Avatar
HR says 90.247 L net.
Old 14th March 2010, 07:33 PM   #17
...hmm, would be a impressive sub if crossed at ~80Hz. Btw, anyone knows if AE have dealers in Europe? Have been searching without result.\
Peter
  Reply to this post
open backed Tapered TL? reverse-taper-into-BIB? zero-net-taper-1/2 wave resonator?Hide this!Advertise here!
Thread Tools
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 06:05 PM
Open backed boxes ? Anyone ? norman bates Full Range 37 6th September 2008 03:19 AM
Do TL lines need to be smoothly tapered? GuyPanico Subwoofers 5 16th April 2005 09:01 PM
Calculating bends in a tapered TL bwbass Multi-Way 12 5th February 2005 09:58 PM
TL tapered design help/comments sunil Multi-Way 10 14th September 2004 03:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
