12" full range. help needed
Old 7th March 2010, 05:05 PM   #1
superfunk is offline superfunk  Italy
superfunk's Avatar
Default 12" full range. help needed
Hi all. That's my first post here, so be nice please.
I won an auction on e-pay for a pair of 12" Visaton
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
now i need to put them into some nice shaped boxes...
i wish on a good performance from around 35Hz to 20KHz (if it can go lower, i surely won't moan).
I'm not worried about WAF, i live alone in a tiny
High SPL are not needed, but they're always welcome.
The tiny room is 3,5 x 5,5 metres x 2,60 tall.
Last weekend i went to an audio convention (if that's the right word) and had the chance to listen at different systems.
I was very impressed by two Systems: one with "Avantgarde Solo" and the other with two set from "Horn Manufaktur"
the models were these two:
A90 - diffusori a tromba audiophile
A100 - diffusori a tromba audiophile
As you know, the Avantgarde has a bass reflex on it's back and uses a specifically designed built-in amplifier, with a moulded frequency responce, so this is not possible for me to build
The other two speakers are backloaded horns, but they use their own drivers.
Do you think it's possible doing something similar with the 12" Visaton?
I like the Dallas 2 design a lot, but they're for 8".
Is there a nice folded horn to accomodate a 12" driver? any suggestions?
I would also consider Onken as second choice, but i don't know much about them. Bass reflex is simply not my cup of tea.
Thanks in advance.
Old 8th March 2010, 02:01 AM   #2
mashaffer is offline mashaffer  United States
Will need to know the specs (fs, Qts, Vas at a minimum)
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Old 8th March 2010, 03:46 PM   #3
superfunk's Avatar
Hi, this is what the seller wrote on the auction page:
30 cm in diameter
8 ohms
100 watts RMS
40 Hz Resonant Freq.
Eq. Volume 180 VAS (liters)
0.68 Qts
this is from the visaton website:
fs Qms Qes Qts Vas Sd Mms B xl L
40Hz 3.59 0.84 0.68 180l 511cm ² 33g 8.2Tm 1mH
Old 8th March 2010, 04:25 PM   #4
Glowbug is offline Glowbug  United States
Glowbug's Avatar
With a Qts that high, open baffle might be something to look into
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 8th March 2010, 05:37 PM   #5
superfunk's Avatar
Oh no, so i bought the wrong stuff...
There is something unconvincing (to me) about open baffles...
and, if not said before, i prefere avoiding the bass reflex boxes. i just don't like them too much and wish to try something different.
If a "classic" backloaded horn is not a good thing with these, what about a "vott-style" or even a "tannoy wannabe" onken enclousure.
The problem is i don't know much about both.
If the high frequencies won't be convincing, i will play with a supertweeter, just to add some fun and learn something new.
Any suggestions on something to make them sound good?
Old 9th March 2010, 01:23 AM   #6
Hmm... Qts like that could be used for a largish sealed box but with a 6.4 ft^3 Vas it would be a substantially largish box. You might be able to go aperiodic. On the other hand since you were thinking horns then a big box is apparently not a deal breaker.
Hear is another thought. Maybe you can try a transmission line. The Vas again will probably rule out really small but maybe...
What bothers you about OB? That Q is actually on the bottom end of what I consider appropriate for FR OB but the fairly low fs probably makes up for it to some degree.
Old 9th March 2010, 05:51 AM   #7
GM is offline GM  United States
GM's Avatar
Greets!
For my records, which model Visaton is this?
Anyway, getting ~flat down to 35 Hz with a 40 Hz Fs, relatively high Vas, Qts driver = huge, like ~540 L for an Onken, which BTW is a bass reflex.
BLHs are designed to load the BW below the driver's mass corner (~2*Fs/Qes), so it wants a horn that only loads below ~95 Hz, i.e. your room isn't big enough for two horns that start with a throat area the size of a 15" driver. Even a relatively 'small' TL is 340+ L.
Really, to get a theoretically good performance out of them in a relatively small cab (< Vas) requires a well damped bass reflex, but it will have a relatively high F3.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th March 2010, 02:46 PM   #8
superfunk's Avatar
thanks for the replies.
Visaton FR31NG 8ohm.
Don't know if it's a good driver or not... i just bought it to start experimenting this stuff. I paid 70euro for the pair, shipping included. nothing so painful.
Forgot to say: on the box it's wrote f^3-15KHz, so i may add up a supertweeter in the future. (or change the whole thing)
Do you consider the onken a good idea? it really temptes me, because if i like it, i could think to get a 12" coax tannoy for the future, or something more hifi.
I have the suspect that they sound "light". i'd like that pounchy feel out from a kick drum... i've only heard a OB in my life, it was lovely, but nothing special (to my ears).
Anyway, i've discovered last night the sigle PA on the box.
Maybe this thing is not going to sound any magic, but my initial thoughts were to find a good enclousure, taste it and then see if it's worth getting a great driver.
If you think a onken can be used with good results, can you put me in the direction of the design? does exists a calculator to draw the litres needed and things?
should i completely discard the idea of a BLH?
Old 10th March 2010, 12:52 PM   #9
superfunk's Avatar
up... i need help.
am i better to discard the idea of a BLH?
is it a good idea a onken?
Old 10th March 2010, 01:07 PM   #10
freddi is offline freddi  United States
freddi's Avatar
12&quot; full range. help needed
if it has a clear midrange and treble then it should play reasonably well in the original Karlson 15" enclosure with the driver centered on an adapter board. I've used EV SP15B in K15 and their Q was >1.
12&quot; full range. help neededHide this!Advertise here!
2 Norelco/Philips Full Range 12&quot; Driver Speakers 9762M FOR SALE screamer025 Swap Meet 0 24th June 2009 10:50 PM
Audio Nirvana Super 12" full range in open baffle - 95db 8 ohms Electro3000 Swap Meet 8 19th May 2008 03:39 PM
RE: Rare full range driver DUODE 12&quot; movingcoilguy Full Range 8 3rd September 2007 10:51 PM
8-12&quot; Bass reflex Full range Corner speaker (mono) Howismydriving Full Range 2 23rd October 2005 07:50 AM
