Full range active speaker
Old 24th August 2009, 12:28 PM   #11
RAndyB is offline RAndyB  United Kingdom
Originally Posted by Dr.EM View Post
Since you'll be using longer than usual "interconnect" leads and the signals carried by them will already be attenuated, I'd reccomend fitting the active speakers with XLR connectors and a balanced line reciever inside. You then need a balanced line transmitter at your pre-amp. Using a passive attenuator with high output impedance and long unbalanced cable runs is likely to introduce a lot of noise.
I have JX92S and Hypex 180 as Chris is planning. The amps. have balanced input by default, and I have put in XLR connectors. Having not yet built balanced drivers, as a temporary measure I am using twin screen cable with the "cold" input earthed at the "driver" end. No hum and noise.
Andy
Full range active speakerHide this!Advertise here!
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 06:13 PM
Recommend a DIY full-range hi-fi speaker better than a 2/3-way one. cirrus18 Full Range 34 13th December 2008 05:09 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
active crossover vs. full range Vix Multi-Way 4 7th January 2004 07:37 PM
Active equalisation in full range speakers niallsmart Multi-Way 20 7th October 2003 06:11 AM
Copyright ©1999-2019 diyAudio
