The series resistance will probably drop sensitivity to just below the 207, so up to you really. They're both fine drivers.
Thank's. You mean, that the 207, need's more power to drive it ? Well in my case it's not a problem (I think ) .. I will be driving it with full balanced F4 +
Jesper.
Scottmoose said:The 206 will probably have a touch more detail
Our experiments with Brynn had the 126 losing detail with the series R required to bring its bass level up. That could well change with the use of a much better series R. Myself i'd use FE207eN
dave
This ain't a ''comercial driver'' right ?
I was wondering, if it's ok, just to glue ''visible'' part's (With dowel's ofcause) onto the chassis, or am i better off, with both glue+screws here ?
While i am at asking quistion's, i would like some ''Dampin'' material recommodation's too
Jesper.
FE207eN = www.planet10-hifi.com Far better than the standard unit.
Damping material? Up to you. 1in stiff acoustic fiberglass on opposite faces will do the job, or wool carpet underlay.
lykkedk said:This ain't a ''comercial driver'' right ?
Soon it will be... or you can diy your own...
dave
With one of your'e phase plug's right ?
You could perhap's email me, with prices Planet10, if it's the case.
Look's very interesting i think!
Looks like i will go buying some wool-carpet piece's I will be back in build process, with where to put the damping i think, but it's future on.
Jesper.
I have a feeling that it's Enabled Enable process
Happy new year.
Ebbe
lykkedk said:With one of your'e phase plug's right ?
Phase plugs are at the moment in short supply as i switch OEMs.
a 207eN has phase plugs, cone pre-treatment, EnABL, basket stiffening and damping plus a few other details. All will be documented & made available to the diyer in one place eventually (ATM you'd have to bring together a number of posts on disparate threads)
dave
OK.. thanks one more time...
I am about right now to order 2pcs. Fostex fe207e in Germany, and would be pleased if someone would look at the link, to see if it's the right one...
Jesper.
http://www.hobbyhifiladen.de/Lautsprecherchassis/Fostex/Breitbandlautsprecher/FE-AV-Serie/Fostex-FE207E::23.html
Jesper.
- Full Range
- Half Chang to fit my need's ?
