Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
Parsing of links in posts
Closed Thread
Thread Tools
Old 13th June 2021, 07:51 PM   #1
tomchr is offline tomchr  Canada
tomchr's Avatar
Default Parsing of links in posts
As more and more websites are moving to https-only, access to their old http versions is being disabled. This causes links to the websites to render as "Access to this website has been disabled" by the forum software.
Example: www dot mouser dot com parses to Electronic Components Distributor - Mouser Electronics
Would it be possible for the the forum software to be configured to add https instead of http?
Here's the same link typed as: https:// www dot mouser dot com Electronic Components Distributor - Mouser Electronics
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th June 2021, 07:55 PM   #2
tomchr's Avatar
Hmmm... Of course now it works. Moments ago I posted in a different thread and the link text became "Access disabled".
Tom
Old 13th June 2021, 09:24 PM   #3
PRR is offline PRR  United States
PRR's Avatar
"Blocked" comes up a lot when a website refuses hot-linking its content into another site's content; usually these work fine when clicked or when Right-Clicked "New Tab".
Deep link into DigiKey: Blocked
The web has had a rough week. Major CDN outages. Mostly fixed quickly; you have time to complain and then you look silly because they fixed it already.
Old 16th June 2021, 05:06 AM   #4
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
This appears to be working as intended, closing. Also to note - we will be moving to XF soon (well into the build phase), and link rewriting will be revisited with fresh eyes.
Closed Thread
Parsing of links in postsHide this!Advertise here!
Thread Tools
"Today's Posts" has disappeared from Quick Links (?) Mark Johnson Forum Problems 3 8th November 2020 10:34 PM
Links to posts depend on "correct" #posts per page to work benb Forum Problems 47 17th March 2016 12:16 AM
Parsing the Supertex LR8N3 HV regulator jackinnj Power Supplies 2 9th October 2013 01:22 PM
where to buy tri-wire binding posts or links deanxxx Multi-Way 3 21st May 2012 01:24 PM
Problems with posts/links Samuel Jayaraj Solid State 0 9th January 2002 08:25 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
