Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
images
images
Old 21st September 2019, 06:55 AM   #1
arivel is offline arivel  Italy
Default images
Hello .
I would like to create a discussion and insert photographs in the middle of the text, so not all at the bottom of the page. how you do it ?
Old 21st September 2019, 08:53 AM   #2
Mooly's Avatar
images
Attach your image in the normal way and then click the symbol here which will list all the attached images.
You can then click each link and the required link text will drop into your post which will display as the image when you post. You can copy and move the links around your post as desired.
All this will change when we move platform and the image hosting of XenForo should be much smarter.
Old 21st September 2019, 09:44 AM   #3
Hello and thanks
I did a test but when I click on preview post the image does not come out but this: [ATTACH] 782543 [/ ATTACH]
does it appear only when it is finally published?
Old 21st September 2019, 11:54 AM   #4
Mooly's Avatar
images
It should show up in a preview. Lets try it... yes it does.
Old 23rd September 2019, 12:07 AM   #5
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Clicking on those images takes me to a new page where only the picture is viewed which is not particularly user friendly.
How come some pictures are able to be panned in and out, while others are not, and how do one attach a picture so the picture do become pan-able?
This is the HTML code for one of the pictures in post #2:
<img class="tcattdimgresizer" src="https://www.diyaudio.com/forums/attachments/forum-problems/782534d1569052108t-images-aleks-png" alt="images-aleks-png" style="margin: 2px" title="images-aleks-png" border="0">
which differs from an attached picture which is pan-able as seen in another post, the main differences are emboldened and underlined.
<img class="tcattdimgresizer" src="https://www.diyaudio.com/forums/attachments/multi-way/779763d1567787887-birth-15-inch-woofer-spider-assembly-png" alt="The birth of a 15 inch woofer-spider-assembly-png" title="Click the image to open in full size." width="600" border="0">
Anyhow, hope the change to XenForo BBS rectifies the problem with attached pictures.
Old 23rd September 2019, 08:30 AM   #6
Mooly's Avatar
images
So after 30 minutes playing around and looking at your example...
The image is attached in the normal way. You then copy the bit I've highlighted and post that where you want the image.
You then put 'Image' tags around the links... whcih doesn't seem to work using the button... so add them manually.
images-annotation-2019-09-23-082327-jpg
images-annotation-2019-09-23-082505-jpg
images-untitled-jpg
images-annotation-2019-09-23-080057-jpg
Old 23rd September 2019, 08:37 AM   #7
Mooly's Avatar
images
I wonder if the other Image button works... it does.
images-annotation-2019-09-23-083347-jpg
images-annotation-2019-09-23-083656-jpg
Old 23rd September 2019, 09:39 AM   #8
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
images
This is how I always insert images - attach, then use the insert image icon, referencing the link that comes up in the 'manage attachments' popup.
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg, T2. : VSQC Phunk Style, Retro 50W, Filmosound 601, LM4780. : Apex AX-14, TGM-10, TDA7265 (Last in line)...maybe
Old 23rd September 2019, 10:45 PM   #9
Pano is offline Pano  United States
Pano's Avatar
images
Yep. That's the clever workaround on this software.
imagesHide this!Advertise here!
Images in Pm's? M Gregg Forum Problems 2 15th February 2013 05:24 PM
No images Osvaldo de Banfield Forum Problems 2 15th March 2012 07:33 PM
GK1 Images harvardian Tubes / Valves 14 8th October 2002 01:00 PM
Copyright ©1999-2019 diyAudio
