Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
Post number link not correctly positioning after rewrite url using an anchor
Old 29th November 2018, 10:11 PM   #11
Dave Zan is offline Dave Zan  Australia
Originally Posted by Pano View Post
Your link took me to post #120 where there is a PDF attached...
The PDF is not the point, post #120 has a link to another post.
That link does not work, for me anyway, presumably because I use a different number of posts per screen to the OP.
This is despite the fact the OP linked to a specific post, to avoid precisely this problem.
He was smart and used the post number in the text so I just found it that way and didn't mention the problem until I saw Toni's comment.
Best wishes
David
Old 29th November 2018, 10:55 PM   #12
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Got it.
That link doesn't work because the OP didn't copy the link using the number in the top RHS of the post.
This is the correct format:
https://www.diyaudio.com/forums/multi-way/103872-geddes-waveguides-post4469018.html
This is the incorrect format:
https://www.diyaudio.com/forums/multi-way/103872-geddes-waveguides-751.html#post4469018
The incorrect format includes the page number, which doesn't work if you have a different number of posts per page set usually because that page number doesn't exist or make sense. It takes you to page 751, which will be the wrong page if you are at 50 posts per page, then the hashtag (anchor) part of the URL tries to take you to an anchor which doesn't exist.
TLDR; When you want to make a link work, copy the link from the post number.
So the problem being reported is, I think, if a post has a quote, and a quote has a link in the "Originally posted by" area, this link doesn't work if you have a different number of posts per page setting than the default. I consider that a pretty major bug concerning core functionality of the forum, so I'll definitely try to fix this ASAP using some kind of hack, instead of saying "let's wait for XenForo".
Old 29th November 2018, 11:50 PM   #13
Jason's Avatar
Ok, I believe I have fixed this (it was pretty deep, to do with layers upon layers of "SEO friendly" rewriting voodoo) and now I believe that the link that appears, in quotes, should work for everyone no matter how many posts per page they are using:
Originally Posted by gedlee View Post
Hi Art
As I have said, over and over, what I am saying will likely only occur for an exactly OS waveguide. Just "smoothing" the throat will not do this.
In this case, perhaps.
How do you explain the fact that an OS waveguide has a lower DI than a rigid piston in a baffle? If the waveguide did not "pull out" the directivity then it should follow the piston.
I think that we are all arguing different things. I know that most horns beam. What I am saying is that beaming is not inherent in the theory, it is a characteristic of the specific design. In theory there is no limit to the HF range of CD on an OS waveguide. That said, different drivers will have different wave front shapes at these very HFs and this will effect the HF polar pattern - probably in complex ways that might change from driver to driver - because, despite design intent, the wave fronts in these devices is not flat (see the paper previously post by WG for proof of this. But this is because the phase plug is not properly designed (see my patents). SO in practice we are likely to see varying degrees of beaming from waveguide to waveguide and driver to driver, but this is not because of the aperture size - that is irrelevant - it is a limitation of the Bob Smith phase plug and the fact that this design will not create a flat wave front at the exit aperture.
Old 29th November 2018, 11:51 PM   #14
Jason's Avatar
The above uses the link format:
https://www.diyaudio.com/forums/multi-way/103872-geddes-waveguides-post4469018.html#post4469018
Which should do the trick.
Old 30th November 2018, 12:55 AM   #15
Originally Posted by Jason View Post
That link doesn't work because the OP didn't copy the link...in the top RHS of the post.
I did explicitly request the OP to use the link to a specific post but I missed that he messed it up.
I shouldn't have assumed, thanks.
Best wishes
David
Old 30th November 2018, 12:58 AM   #16
Jason's Avatar
In fairness, the forum should make these things easy and impossible to mess up. If you need a link in a previous post edited let me know.
Old 30th November 2018, 01:31 AM   #17
Pano is offline Pano  United States
Pano's Avatar
Works for me.
Old 30th November 2018, 01:34 AM   #18
No criticism of the OP, only my failure to check.
Links are all fine, thanks once more.
Best wishes
David
Post number link not correctly positioning after rewrite url using an anchorHide this!Advertise here!
Help!! i just bought a $150 boat anchor seppaku Car Audio 13 14th June 2013 11:25 PM
Registered post number [RESOLVED] Pocoyo The diyAudio Store 3 28th December 2012 08:10 AM
It seems my new threads don't post correctly tomchr Forum Problems 9 13th January 2011 02:07 AM
FS: Mapleshade Tube Anchor A Milkduds Swap Meet 0 16th September 2009 04:05 AM
Copyright ©1999-2019 diyAudio
