Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
What audio system do you have?
Old 19th July 2002, 07:08 PM   #11
gromanswe is offline gromanswe  Sweden
Account Disabled
Send a message via ICQ to gromanswe Send a message via AIM to gromanswe Send a message via Yahoo to gromanswe
Originally posted by Bill Fitzpatrick
<blockquote>Why don't you start a new thread called, "Tell me what you have and I'll tell you what's wrong with it." I'll reply, outlining my system as I have done here, and you can bash the hell out of it.
</blockquote>
Bill,
Unfortunately we have both met the kind,
But don't worry to much,
the majority of readers at this forum
dislike the attitude of those ones.
They do not only spoil the fun for the rest of us,
their remarks probably makes themselves feel awful inside.
http://www.diyaudio.com/forums/showt...2441#post42441
gro
Old 19th July 2002, 07:41 PM   #12
Jules is offline Jules
Modified Oracle delphi, Slate base, diy power supply, cones.
Rewired Rega RB300 arm with same cable (discovery) from cartridge to phono
ADEQ (ben duncan)phono amp sits underneath the base eliminating the need for 1/2 metre of arm cable.
Kiseki blue cartridge.
Pioneer cd transport with Trichord clock and battery power supply
Deltec PDm2 dac.
Diy passive with dual stepped attenuators. ( only 13x 2db steps, but in practise 26 db is plenty of range)
Kelvin labs 60 watt Class A monoblock power amps ( to be Aleph 2's sooner or later)
Apogee Stage speakers.
Low capacitance i/connect, very short (1/2 metre) VDH speaker cables (biwire)
Sounds very good, needs a bigger room to do justice to the Stage's low end but my wife won't give up the lounge.
Jules
Old 19th July 2002, 07:52 PM   #13
Account Disabled
Thumbs up Jules
PRECISELY!
That makes a simple stepper be a very WISE choice.
(As I have described in another thread,
use of CMOS up/down counter and Analog Multiplexer,
with remote control)
With 11 steps you come a long way.
For precise messuring purposes it can be different,
but I neither have the time or desire to messure
every song I enjoy.
Old 19th July 2002, 07:54 PM   #14
chris ma is offline chris ma  Canada
chris ma's Avatar
Default 4 Koss for L/R
Dave you are correct, I prefer the BW302 to those Koss.
What I used to do was to the Mirage 490is connected to both the Rotel and the JLH all the time for using it as the main L/R in the 5.1 setup as well as for the JLH 1996 as 2 channel only, and I think that was kind of dangerous. But I have not enough savings for another set of half decent speakers for the front and actually space to put them, the Koss can just sit on the top of the TV for now, if I switch the BW302 as the front I have no place to put them... until I have a better solution then the Koss will be moved to my daughter's room or basement background music when I am soldering.
Chris
P.S. I've forgotten to mention that I have D-Box david300 and JBL 8" 150watt subwoofers for the home theatre in my last post
Old 19th July 2002, 08:09 PM   #15
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Well, since it was asked, I guess I'll describe my system. Nothing, zippo, it's all gone. I got rid of everything and am slowly rebuilding the hole thing. It's all comming along nicely, only thing not started is the sub (haven't decided what to go with yet, I'll do that when everything else is finished). Here's what' being built...
speakers: bi-amped vifa P17WJ-00-08s and BG ribbons
crossover: 24dB/octave linkwitz-reily discrete crossover
amps: power follower 99c's driver by tube voltage gain stages (for both the highs and the lows).
Haven't heard it yet, but shouldn't be too long before it's done. Oh, and I don't care if it doesn't live up to some of your standards, it's fun to build .
Old 19th July 2002, 08:29 PM   #16
Account Disabled
Default I feel fine /Lennon-McCartney
JoeBob
This meets my standard.
In fact, anything that makes you feel good does.
Best Wishes
Happy New Year
gro
Old 19th July 2002, 08:44 PM   #17
willryu is offline willryu
Default My systems
Primary system
Speakers: Reference 3a Royal Master Control Monitors, HSU VT2 subwoofer
Amp: Tripath Eval Board (TA0104A)
Preamp: Passive stepped attenuator (50k Ohm)
DAC: ART DI/O with typical mods (Opamp upgrade, schottky diodes, higher VA transformer)
Transport: APEX DVD (AD600)
Secondary System
Speakers: 2 sets of KLH Model 9 Electrostatics
Amp: AudioPrism Debut (35 W EL34)
Preamp: DIY battery powered Opamp based pre (OPA627)
DAC: Audio Alchemy DDE 2.0
Transport: Lite-on CDROM
Headphone System
Headphones: Sennheiser HD600
Amp: Meier Corda HeadAmp-1
Source: Same as secondary System
Other rooms
3 Rio Receivers fed by mp3s from home server.
-willryu
Old 19th July 2002, 08:44 PM   #18
Account Disabled
Default I am enjoying
Come Together from Album "Abbey Road"
right now
MAXIMUM bass control
Paul John George Ringo
still unsurpassed team
33 years! later
Old 19th July 2002, 08:52 PM   #19
bstanton is offline bstanton
Audax 12" aerogel powered-sub (designed by Joe D'Appolito), Audax bookshelf rears (designed by Vance Dickason), my own design for fronts and center (a 5" Focal polyglass woofer and a Vifa silk tweeter). I'm using my Toshiba DVD for CD's but I'm going to start desgining a DAC that will connect to it with a Toslink. Amplifier is 5 channel Harman-Kardon, but I have one shelf cleared for a McIntosh amp (someday)!
Old 19th July 2002, 09:03 PM   #20
Account Disabled
Default fotenote
Vance Dickason, Author of "Loudspeaker Design Cookbook"
The Worlds Most Read publication
regarding Loudspeakerbuilding.
Get your copy! Soon as possible!
What audio system do you have?Hide this!Advertise here!
My Audio System (for the time being...) victoriobenatti Multi-Way 1 18th June 2008 01:04 AM
Detachable car audio system. v-bro Car Audio 5 9th January 2007 11:32 PM
car audio system needs help stephen22 Class D 14 13th March 2006 07:32 AM
5.1 audio system for PC Qub Everything Else 3 2nd February 2006 05:57 AM
System Audio 1270s Positron Multi-Way 0 15th June 2003 12:50 AM
Copyright ©1999-2019 diyAudio
